Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
z.monkey
Howdy Nievesoliveras,
I believe this is where we started...
Blessed Be...
Goodwill to All, for All is One!
nievesoliveras
Hi!
The similitude of the electrinium battery with the hutchison battery is tremendous.
One guy did this, and got an almost permanent battery:
"Get a pound of MAP.
MAP stands for "Monoammonium Phosphate". It is a piezoelectric fertilyzer material.
Place some MAP in 2 layers of coffee filters and tie it off.
Put that into a pot of distilled water and boil it till water is well saturated with MAP.
Pour the liquid into a small SS pan (12cm x 14cm) and evaporate it with a convection oven till a thin coating of MAP crystals is left.
Continue heating it on the stove till the MAP melts and then place aluminum foil on top.
The SS pan is the positive. The aluminum foil is the negative.
Zap it with about 10kV from a flyback transformer.
Let it shorted out for a few days with a 10k resistor.
You should get over 600 mv every time you check it and a steady 60ua of current.
Them try shorting it with 1k resistor. It should give 600ua at 0.6v.
If you get less than that, then that is the maximum.
Shorting it will increase the output instead of decreasing it. Measure without the resistor.
The ideal dimensions of the ss should be (3.5in L x 2in W)."
This is just fuel for the thought of you good thinkers and experimenters.
Jesus
nievesoliveras
Hi!
Zmonkey
I did not know. I will keep looking for some answers though.
Jesus
resonanceman
I finally   finished  reading the  Electtinium PDF
One thing that has  got me wondering is  why he  chose to explain how to make the  silicon based version.
The body of the Unit could bc made from a number of materials such as steel, Silicon,
Germanium, Carbon and others. Each of these materials would be suitable for an Electrinium Unit
designed for a particular purpose. Units made with steel bodies would be of an extreme voltage,
so high that they could not be cut and assembled into batteries, but they would be very easy to
m a ke. By using the steel as the nega t ive and Gold or Platinum as the positive, to make the
c o m p o u n d the compound becomes the body. All that remains to be done is to shape the body,
harden it and organize the electrical forces in a series.
If  units  with steal bodies would be  easy to make  why not  explain how it is done ?
Making your own  custom  single crystal silicone  structure is not  easy by any means .
because  of  what he said about the  high  voltages I would think that   we would have to make the junction  very thin .
I can see how it might work using  carbon / iron.   but   gold / iron  has me stumped.
He  says that the compound becomes the body .   So  far  I am thinking that the way to do it is to  put a little   gold /steal compound between 2 plates and  heat them up enough to fuse  them together.
I am not sure if  one of the plates should be gold plated.
He talks about using  Sodium Cyanide to make the electrolyte.      Would other electrolytes work ?
If I remember right  if you  handle  Sodium Cyanide wrong you can find yourself in  your own self made  gas  chamber ..
gary
resonanceman
Quote from: nievesoliveras on September 25, 2008, 09:56:24 AM
Hi!
We are trying to make an electrinium battery. To get the electrinium battery, we need to form some cristals. There is this process that may be useful to understand the crystals we need. May be we can grow the crystals instead of getting them with a metal fusion.
Kayex Silicon Crystal Growing Process
http://www.kayex.com/silicon-crystal-growing.asp
Jesus
Jesus
Z Monkey already  had a link to that machine back on reply 15 .
Are you volunteering to buy one so we can get started?
Z monkey  said they  only cost about $500k
;D
gary
