Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
jeanna
@ zmonkey,
thanks. That is a great answer.
I may try the HHO thing just to see, anyway. I saw in a Yull Brown/HHO movie online somewhere, where he changes rocks with the welder and makes the surface get shiny and hard. Since I want it to work, I will see if I can get somewhere on it.
@ Jesus, I think there are lots of threads here at OU on HHO where the participants can help with the build. ( For instance, too much electrolyte makes too much Amperage and too much heat. etc.)
I only mention the HHO welder because I think it is a small and cheap way to possibly achieve this crucible effect with the Silicon and make a crystal.
Thank you,
jeanna
resonanceman
Quote from: jeanna on September 28, 2008, 01:30:37 AM
I am unclear what this electrinium that you are using is. Do you have a consensus about it?
I thought it was the used sludge in a dead battery. (carbon - zinc?)
Jeanna
Yes it is  the  sludge  left  behind  after a battery  has been used for a while.
Chapter 10
THE FIRST ELECTRINIUM UNIT
Let us make a small model Unit. Let us use time-tested elements and processes already in use
today. Let us select Silver and Iron for our Electrinium Compound. Iron and Silver are being used
in many of the new and improved batteries of the world. Silver will be the positive element and
Iron the negative. If we could find a worn out Silver-Iron battery there would be enough Silver-
Iron compound in its bottom to make many Electrinium Units. Or, let us build a small storage battery
and compound our own Silver-Iron molecules through the discharge-charge process. The battery
need not be large. Four sheets of Silver, size three inches by four for the positive side, five sheets
of Iron for the negative using lead terminals for each side. We will assemble them in a standard
battery form using separators cut to size from and old battery. A five inch square glass refrigerator
jar could be the case. We can compound our electrolyte from distilled water and Sodium Cyanide,
compounded to a density to provide a circuit of conductivity of two and a half volts resistance
reading on the voltmeter mounted within the circuit. This battery can be fabricated very easily at
a very low cost. A few hours of use will produce enough Electrinium Compound to make one or
more Units.
I don't  remember ever seeing a  silver  iron  battery .....
He  talks about how important harmony  is in  chapter 9   but  the  only  electinium  compounds   he mentions in the  PDF are  gold silver  and  platinum  each  pared with iron
gary
hypersoniq
@ Drannom... Whatif you were to layer what you need all in one "grow"? In such a manner that your constituent components (like flowing in the K Alum) could be switched midstream with a new substance...
I used to work with MOCVD reactors that grew laminated laser diodes on an indium substrate. THey would heat up the indium disc and flow different materials around it (cladding/active region[N/P regions]/cladding). The biggest concern was lattice matching (which they checked via X-ray).
I imagine it would take some research into the crystalline lattice matrices of each constituent component to get a close match at each phase without voids or the possibility of de-lamination,but it would be an interesting idea to just "grow" this whole thing in one operation and avoid any fusing/welding/torching operations completely...
is that possible? have you ever changed or added ingredients while making one of those pyramids?
Drannom
Quote from: wizardofmars on September 26, 2008, 08:01:07 PM
So you believe the Illuminati are involved? Very interesting.
Can you substantiate your claim that Tesla was removed from history books prior to the Internet?
Did the Illuminati overlook the following books which are pre widespread Internet use (~1995 by my reckoning)? Would I be able to find these books in a library or would they have been seized by the Illuminati already?
    * Anderson, Leland I., "Dr. Nikola Tesla (1856â€ââ,¬Å"1943)", 2d enl. ed., Minneapolis, Tesla Society. 1956. LCCN /L
    * Auster, Paul, "Moon Palace", 1989. Tells Tesla's story - among other's - within the history of the United States.
    * Cheney, Margaret, "Tesla: Man Out of Time", 1981. ISBN .
    * Childress, David H., "The Fantastic Inventions of Nikola Tesla," 1993. ISBN
    * Glenn, Jim, "The Complete Patents of Nikola Tesla," 1994. ISBN
    * O'Neill, John Jacob,"Prodigal Genius," 1944. Paperback reprint 1994, ISBN .
    * Ratzlaff, John and Lee Anderson, "Dr. Nikola Tesla Bibliography", Ragusan Press, Palo Alto, California, 1979, 237 pages.
    * Tesla, Nikola, "My Inventions" Parts I through V published in the Electrical Experimenter monthly magazine from February through June, 1919. Part VI published October, 1919. Reprint edition with introductory notes by Ben Johnson, New York: Barnes and Noble,1982, ISBN; also online at "My Inventions", 1919. ISBN
yes you are right, Tesla was not erased, i read somewhere that Marcony is claiming to be the inventor of radio waves communication in some old hhistory book, in fact it was Tesla !, then many brevet patented from Tesla were used and no one mention that is coming from Tesla, Tesla's invention has been used illegaly, this is what i think and i may be wrong, i read that somewhere
@all
i am about to read the chapiter 9 and it is more wonderfull than ever cause i have a better understanding in english now, i have learned up to now what is the meaning of gravity from electrinium and it is different that the theory in the Super Light link, so which one is the real one gravity theory, my brain will brainstorm on it for a while
@Jesus yes i know all about Brown Gas, one of my friend have it ! but for my purpose i just want to get two metals heat up to a liquid state
anyway i have to finish to reread the electrinium again, hahaha
i am happy to see resonanceman read it cautionnally too
i will come back in few days with my new concept of the steel electrinium
now we have 3 type of electrinium to study, with iron-carbon, with iron-silver, and thanks resonanceman we have a third kind with old silver-iron battery
keep going studying
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
resonanceman
Quote from: hypersoniq on September 28, 2008, 04:55:23 PM
hypersoniq
I think it  would be possible ..........but I am no expert .
I tried to  explain my ideas about it  back on reply 105.
gary
