Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
kacor
@Loner
To answer your question there is a quote
SM Fairy Tale
Quote. the king was  relieved that they had taken the shortcut  ..but when he saw all he other uninvited guests he realized that disconnecting the main return wire was a bad mistake. He grabbed a few of them and put them to work ...he was able to send some of the  others back down the original wire in the hope that they would find another king to annoy But there were too many of them so he quickly found another big wire that led somewhere else and joined them together. he managed to get most other uninvited guest to go down that one, away form his kingdom.. told them tell the others that the party was over but they were having such fun ,weaving and winding ..jumping and pushing.
@ all
I don't know how many of you have read that fairy tale, and also don't know how many of you think it is really not a tale.
Bless you all
Kacor
wattsup
@sparks
Regarding the Cook coils, I had built 3 of them in variations of winds and materials. The best one is still the first one I made (right) using iron wire core. Funny I was thinking of taking them out again under some new pulsing methods (when I have the time).  Regarding the Cook coils, it is said that it should be used in tandem with other driving methods or apparatus but I have not figured it out yet, The way the original patent shows the connections as a cross from one primary to the other secondary and back make for some weird scope shots when pulsing either AC sine or DC. There is more on these builds in this thread: http://www.overunity.com/index.php?topic=2630.msg37613#msg37613
This week I am going to make a new FTPU outer ring using the same iron wire (insulated) and wind some coils over it to see the effect.
forest
Quote from: wattsup on January 25, 2009, 01:17:23 PM
@sparks
Funny , I have built my tpu the same way as brnbrade coil, except output coil is crossing iron core like in Gunderson patent. That was my theory based : instead of rotating magnetic field, just allow to create stationary electric waves in coils around core and let the Earth rotate it.
If that works , and it should according to MCFarland and others the problem remains , how to collect electricity for output.
forest
What's going on with brnbrade topic. All responses from brnbrade was removed ! I wanted to follow that topic but it's really hard because all responses are removed !
MACEDONIA CD
@watsoup
i see  your coils  i see in the midle coils  there is  two coils  i thing   you whill have some dc  voltage  very small dc voltage if  you  put two separated  long  antenas  simple wire  i thing is like caps   is charging itself  whit potencials   charging     THING  LIKE THIS AND TRAED THIS  ONE COIL IS  LIKE  ONE PIN FROM CAP  ATHERE COIL IS   ANTHERE PIN FROM   CAP  AND I THING YOU WHILL HAVE  SOME  TO COLECT  OF  FREE ENERGY   OR
OH  TO NOT FORGET  YOU MAST MAKE  3 COILS  <PICK UP COIL  TO   GET  SOME POTRNCIAL  DC VOLTAGE  FROM THIS TWO  COILS   WHIT  THIS  ANTENAS
8)
I WHILL SAY SOME ATHERE    POTENCILA  ELKTRICYTY  IS MORE POWERFULL THEN  CLASICAL ELKTROMAGNET FORCE FILD  WHIT THIS   YOU ONLY NEED JUST LITLE  INPUT  TO  PICKUP  DC VOTAGE
