Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
MACEDONIA CD
hmmmmmmmmmmmmmmm
IMAGEN  LIKE  YOU HAVE  MAGNETS  << particles >>  IN   TO THE  SOME TRIODE
AND  THEN YOU WHILL NEED  ONLY CONTROL GRID   ;) ;) ;)
  SUMARY OF THIS  IF YOU TRANSFORM  <<ELKTRONES  TO MAGNETS <<particles>>.>
THEN ??? ??? ??? ???
EMdevices
I want you guys to suceed in your endevours because this TPU technology is amazing no matter where the power comes from,  but in case you guys missed it:
   you can pulse all sorts of geometries and cores untill you're blue in the face,  but you won't duplicate SM's technology unless you are close to powerlines  and have that INHERENT FREQUENCY OF THE EARTHS MAGNETIC FIELD surrounding your device.
So go experiment in the proximity of powerlines and your sucess will quickly follow !  (100 ft is close enough, don't go any closer)
According to the "master", energy has to come from somewhere and SM couldn't be more plain and direct when he said his device converts energy and is tuned to the earth magnetic field (in the first video), and there is a whole lot of energy in the proximity of powerlines going up into the kHz frequencies, and the fact that the mansion is near HV lines is not simply a coincidence, it is part of the secret !
I'm just trying to help,  it pains me to see folks talking about such esoteric subjects and cherished fantacies.   At least, test these exotic devices next to powerlines and then you might stand a chance to suceed !!!
EM
forest
Quote from: EMdevices on February 02, 2009, 01:28:37 PM
EM
Oh NO! EM if you solve how cyclones are powered by proximity to powerlines I would be glad if you start another interesting thread of discussion...
Meantime, I will give you some interesting info. Once upon a time Tesla considered a metallic  ring turning around Earth equator in direction opposite to the rotation of Earth.He surely was able to imagine the huge current flowing inside such metallic ring.But that was theoretical investigation,right ? Hmm...
Read this :
"When the brush assumes the form indicated in Fig. 16, it may be brought to a state of extreme sensitiveness to electrostatic and magnetic influence. The bulb hanging straight down from a wire, and all objects being remote from it, the approach of the observer at a few paces from the bulb will cause the brush to fly to the opposite side, and if he walks around the bulb it will always keep on the opposite side. It may begin to spin around the terminal long before it reaches that sensitive stage. When it begins to turn around principally, but also before, it is affected by a magnet, and at a certain stage it is susceptible to magnetic influence to an astonishing degree. A small permanent magnet, with its poles at a distance of no more than two centimetres, will affect it visibly at a distance of two metres, slowing down or accelerating the rotation according to how it is held relatively to the brush. I think I have observed that at the stage when it is most sensitive to magnetic, it is not most sensitive to electrostatic, influence. My explanation is, that the electrostatic attraction between the brush and the glass of the bulb, which retards the rotation, grows much quicker than the magnetic influence when the intensity of the stream is increased.
When the bulb hangs with the globe L down, the rotation is always clockwise. In the southern hemisphere it would occur in the opposite direction and on the equator, the brush should not turn at all. The rotation may be reversed by a magnet kept at some distance. The brush rotates best, seemingly, when it is at right angles to the lines of force of the earth. It very likely rotates, when at its maximum speed, in synchronism with the alternations, say 10,000 times a second. The rotation can be slowed down or accelerated by the approach or receding of the observer, or any conducting body, but it cannot be reversed by putting the bulb in any position. When it is in the state of the highest sensitiveness and the potential or frequency be varied the sensitiveness is rapidly diminished. Changing either of these but little will generally stop the rotation. The sensitiveness is likewise affected by the variations of temperature. To attain great sensitiveness it is necessary to have the small sphere s in the centre of the globe L, as otherwise the electrostatic action of the glass of the globe will tend to stop the rotation. The sphere s should be small and of uniform thickness; any dissymmetry of course has the effect to diminish the sensitiveness. The fact that the brush rotates in a definite direction in a permanent magnetic field seems to show that in alternating currents of very high frequency the positive and negative impulses are not equal, but that one always preponderates
over the other.
Of course, this rotation in one direction may be due to the action of two elements of the same current upon each other, or to the action of the field produced by one of the elements upon the other, as in a series motor, without necessarily one impulse being stronger than the other. The fact that the brush turns, as far as I could observe, in any position, would speak for this view. In such case it would turn at any point of the earth's surface. But, on the other hand, it is then hard to explain why a permanent magnet should reverse the rotation, and one must assume the preponderance of impulses of one kind."
Similar concept was a theme of long conversation between me and my friend. All I always knew is that : if you be able to produce current inside SOMETHING (like plasma or air) which is rotating in different direction then Earth , or not rotating with Earth or at least rotating slightly slower then Earth surface, then you would be able to tap really large amount of power by using potential difference and charged particles. Apparently it's not a theoretical task, because cyclones exists and TPU also. ;D
Anyway I'm a theorist only with two left hands for manual work ;-)
Antimon
@EMdevices: When do you finally stop it. Its not possible to get these powers from the power lines. You are always talking, prove it when you have the solution!!
A.
forest
Those pictures are only schematic of what I call "cyclone effect", it's not TPU!
We have a ring or tube of flowing particles (current) in circle.
In Fig 1 we have normal current or particles stream sustained by some force like battery or other. if we turn back the circuit the flow is reversing direction and the output still manifest itself on output wires.
Very symmetrical.
In Fig 2 we have "cyclone effect" - external force is driving particles which are essentially "levitating" in absent of this driving force.Like magnet over superconductor (or opposite ?). This external force is unidirectional so after turning back the ring particles movement is slowed down,stopped and reversed but that's another issue, anyway the output ceased by the configuration of tapping wires (which has to be similar in case of such accelerator ring)
