Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
BEP
Quote from: EMdevices on February 10, 2009, 08:37:10 PM
Nice drawings there wattsup and marco,
I was looking at the patent posted and the person claims he was getting between 2.5 and 3 volts  from a 5 killowatt AM radio station at a distance of about 5 miles,   wow !!,  now imagine what you can get from a 150 killowatt  "radio station"  100 feet away    LOL   :)   ;D  :)
EM
I hope this idea is true. It would be nice to find the solution.
While the circuit posted certainly works, no different than one of Stiffler's in my opinion, it is a wideband circuit. How does he think the power is coming from 'a' nearby station? The majority, maybe?
Then there is a difference between radiation from a broadcast station and power lines. Broadcast stations are made to broadcast. Power lines null radiation, of the energy travelling in the wires, on at least one plane.
Now, if they are simply used as the primary antenna element and these devices are designed to couple to those lines.... maybe. Certainly not coupling for the line frequency. There is not enough radiated energy. Instead of kilowatts try gigawatts. Still not possible.
Radiated energy is a fun topic. Did you know in thermography you can see a very hot object as room temperature, simply because the object may reflect the overriding lower ambient temperature? I'm talking about hundreds of degrees difference.
Why? Because the volume of the ambient washes out the smaller point of higher temperature and that point is more reflective than emmissive.
Point the same non-contact thermal device to the clear sky on a very hot day (not at the Sun). Do you see the temperature of the air above you? No. Your device should read 'OL' as it can't read the low temperatures of outer space.
I think there may some value in this idea about power lines but it will make no difference if they have voltage applied or not.
BEP
sparks
     Maybe the power companies are getting smart and using the transmission lines to setup some harmonics on em.   Longitudinal emwaves through the skin of the conductor instead of pushing amps.  I think GE is ready to do this.   Tesla was ready to do this but he found the Earth had alot more potential to create standing waves in than what I see up on the towers.    Those conductors are hollow with some kinda dielectric material in em to minimize selfinductive losses.  Big ole piece of inside out coax. :-\  Too bad they didn't spiral wind them.  Resistance of the line would be negligible as the conductor itself would send the signal instead of using all that voltage to push it through.  They do rectify older power lines that are considered inefficient because of selfinductive losses causing hysteris heating in the lines.  BEP says they filter it but how do they filter the load pull?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
Quote from: sparks on February 11, 2009, 10:22:41 AM
I they do this we would not see it because of power transformers used to step voltage down. I bet there is already Free Energy coupled with HV lines, but all is then grounded nicely.
Btw: what is the difference between stationary waves and standing waves ?
wattsup
OK - more hunch time.
What if that damn toroid was wound with litz wire?
I did a google search for "toroid with litz wire" and found only one hit.
http://part15.us/node/1631
It's a good read for coil and antenna builders (rather overunity.comish) , but not much specifics on the toroid with litz wire. Hmmmmm.
If the core had NO flux transfer ability at all, like a wooden core, then the two coils with litz windings would equal the windings in an air core antenna.
The EM Capacitors (two) could wind up being two crystals, one per toroid half then the signal is sent through the rings and outer coils to stabilize the output.
In the OTPU there is evident a circuit board. This could simply be a small AM radio circuit catching the HV line hash and amplifying it. There is also a FTPU toroid in the OTPU if guys remember well enough.
OK I'll stop it now.
wattsup
@Loner
If you could find anything on such Litz toroids, it would be good to see one or to know where to look.
@all
Found something interesting - A Self Drive Piezo Transducer with a resonant frequency of 6800+/-500hz.
http://www.islproducts.com/prod/piezos/P25080P3.htm
So far the only voltage rises I am seeing is in the 10mhz range with DC pulsing.
Question: At one point SM talked about one or two (can't remember) Forum Members that were getting close to the TPU function. Does anyone know who they were or where I can look for it in this huge Forum. Now that I have a very good mental image of the FTPU and OTPU, I think if I could review their posts, something may click.
