Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
rensseak
Quote from: wattsup on February 13, 2009, 08:06:04 AM
@Loner
If you could find anything on such Litz toroids, it would be good to see one or to know where to look.
@all
Found something interesting - A Self Drive Piezo Transducer with a resonant frequency of 6800+/-500hz.
http://www.islproducts.com/prod/piezos/P25080P3.htm
So far the only voltage rises I am seeing is in the 10mhz range with DC pulsing.
Question: At one point SM talked about one or two (can't remember) Forum Members that were getting close to the TPU function. Does anyone know who they were or where I can look for it in this huge Forum. Now that I have a very good mental image of the FTPU and OTPU, I think if I could review their posts, something may click.
As i can remember it one was Freedomfuel an the other was BushWacker with some points of his HOPE-Generator. Unfortunately Freedomfuel deleted his posts.
Norbert
wattsup
@Loner
Thanks. It's Tao. I have been doing some major reading all day long, I mean all day long. Back and forth from the Master of Magnetics thread - then looked up Tao's posts before April 13th, 2007 when Mannix posted on Lord of the Rings.
http://www.overunity.com/index.php?topic=1872.msg28253#msg28253
Then going back to SM statements on Tube testing and other factors of serial and parallel wire schemes when passed over with a magnet, then it hit me.
The FTPU ring or collector is many lengths of insulated magnet wire. Litz wire or if you take many lengths of a thin magnetic wire all in parallel and turn it into a three looped ring about 12awg in thickness. If you want to move a train, you first have to build the tracks. The more tracks you lay, the farther you will go. I don't know if I could find a Litz that is 12awg thick but if I did, It should have a good 1000 wires or more in it. lol
Pulsing the outer control coil wound over single conductor looped ring is not giving any results or results that anyone would expect as mundane.
My next trials will be with a multi-conductor ring. The multi-wires will give amperage and the three turns will give added voltage.
My ring is 7" in diameter so each loop of 22" circ., so three loops is 66" and add 7" on each side for leads and that makes each length to be 80". If I want two rings that's 160". So if I make a rectangular wooden form that is 66" by 14" and wind x turns, then cut in the center of the 14" ends, I'll have my two loop lengths. Easy as pie.
@otto
Found this for you.
SM Quote (yeh yeh I know)
I have made a great study of Vacuum tube power supplies as I have told you. It is all very interesting. Please remind me to tell you why Nicola Tesla used Vacuum tubes in his most powerful demonstrations of his power conversion technologies.
Anyway, I have taken a high voltage power supply as follows:
500 v-0-500 v  300 mV plate transformer run it through a full wave silicon circuit then run it through a 5U4 electron tube rectifier. Now you know that the 5U4 requires 5 volts AC at 3 amps for its heater to gather the electrons and complete the circuit. Well, I measured the output from the tube and the result is 500 volts DC at 250 mV. The loss is due to the high impedance of the tube and its limited ability to dissipate more than 250 mA.. The point I wish to make here is that also along with the 500 volt DC is, yes, you guessed it, the 5 volts three amp AC current! They are both completely independent of each other except for some very interesting things I will mention to you some other time.
SM Unquote
Funny thing. When you put your power supply onto a coil and turn up the juice, sometimes the voltage and amperage reading on the power supply will go way up, 32vdc 5 amps. But then on other coils, when you do the same thing, the voltage and amperage does not go as high. Why is this different on every coil type? When I put my outer ring coils in series from top level then through bottom level, I can go only up to 3 vdc and 4.8 amps. Hmmmmm, About the same wattage as the tube mentioned above. Would it be correct to say that in a way, the coil itself is self regulating the maximum applied input power like a resistor? This tells me the outer coil winding is close so I will do the same on the next ring.
Next ring coming up.
forest
@wattsup
Do you understand why tubes are important ? I think you got it... Show me SS part able to pass low voltage at high current and high voltage AT THE SAME TIME. Tube can do this.
Seems that mystery is simple fact. if you have an inductor and wire or second inductor then current flowing inside generate a second current shifted in phase beside of original one. It's done due to fact that magnetic field does not collapse with infinite speed. Once you do that in circle (with tubes as signal source) kicks are created becouse some of that waves meet at correct time.Voltage and frequency of kicks are depended on wire length, they probably try to lock to odd number of waves along wire length to sustain flow.Stationary waves.
Seems that similar effect is used for antigravity and it's called Lorentz-O by Stan Deyo. However I cannot find the reference for such effect in literature.
forest
Where can I find Mannix 'king's tale' and carl tale ? I saw that mentioned somewhere...
otto
Hello all,
@wattsup
thanks a lot. This was a great help.
Otto
