Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
forest
Nikola Tesla in 1890
probably Clemente Figueras in 1902
Roy Meyers in 1913
Alfred Hubbard in 1919
Lester Hendershot in 1928
Floyd Sweet around 1980
Steven Mark around ????
Paul Baumann around ????
and many others
All seems to have the same design or part of it !!!
A few inductors or transformers in CLOSED PATH, different ways to shift phase of currents and mix them together all around.
turbo
Quote from: Mannix on February 15, 2009, 11:39:39 PM
Em,
Would you say that Henry Moray Tapped the power lines as well?
I don't think so,
They took it to the desert far,far away from powerlines!
Marco.
sparks
    Say we have an electromechanical compass.  We pulse the needle at the proper time it will experience a torque towards alignment with the magfield of the earth.  Like a wind vane.  The other way to gain from the near earth mag field is to establish a magnetic current towards a common low pressure area.  The currents will experience the coriolus force and bend towards the equator instead of impacting straight on.  There must be a magnetic fluid.  You can compress it spin it accelerate it there are equal lines of force just like a weather map.  The wind seems to be blowing south to north.  When you look at the magnitude of the electrical displacement currents running west to east it is no wonder the magnetosphere is so damn big.  Venus is barely spinning it has no magnetosphere.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Mannix
Sparks,
What if we could use just a tiny fraction of what you describe ....BUT 100 thousand times a second.
Steven said that  it was that earths magnetic field in the video for want of a better explanation.
He also said that he/they never knew for sure from where the power came.
He said tubes ..over and over . I dont think he was being economic with the truth . Just sparse on specifics, as also stated.
I also knew that no diagram would be given ..just guidance for personal experiments to head in the right direction, a direction that I notice very few actually take because they are too smart to use tubes..after all, they have been outdated and superseeded havent they?
The only way is to contribute to this is by experimentation using the devices recommended...do join the fun and "sparks"
A geiger counter will be very useful and guess what's  inside them?
Lindsay
EMdevices
@chef
My info on Hendershot comes from a pdf file titled:   The Hendershot Motor Mystery,   inside you find quite usefull info and some hand writen notes, those notes are excellent.
@slapper
I think that is a great idea slapper,  I have even seen patents where they join a piezo and a magnet and coil setup for transduction type of circuits.  I think you got the idea of what I'm shooting for.
@mannix
I haven't read what Moray did in a while, so I won't speculate about it.  I hope the energy received is free and abundent, but if its entering my house I'LL USE IT,  no matter where it comes from.  Be it the powerlines one mile away or that AM radio tower 10 miles away,  if I can tune into it and extract it's my free energy   LOL  :)
@ all,
Here's the beauty of working with magnetic loops instead of antennas:
assuming the magnetic field density permeating my house at a particular frequency is:
b = a * sin(2 pi f t)
where 'a' is some amplitude,
then the voltage induced in a loop of N turns and 1 m^2  of area is as follows:
v = N db/dt = 2 pi f a N cos(2 pi f t)
where it is evident the amplitude of this voltage is now:
|v| = 2 pi f a N
Now,  just think about that for a while,  notice it now depends on the FREQUENCY.  So it is beneficial to receive as high in frequency a signal as possible (but there are always limitations)
If we are receiving a signal at 100 000  Hz,  well that's a 100 thousand multiplication factor right there, don't need any amps to do that, it's the nature of magnetism that does it !!
I hope this gets some of you thinking if you weren't before,  LOL
I've done these calculations before but I'm just amazed how well they work.  Like I was telling you, it amplifyes the signals quite well.   Now all I need is to construct a good high Q resonator which is becoming more of a problem than I thought.  But I'll do it eventualy.   SM spent 10 or 20 years perfecting his devices.  I plan on a much shorter schedule.
EM
