Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
Grumpy
Quote from: Loner on May 03, 2009, 10:21:58 AM
Grumpy, just a little side question, if you happen to read this.  A little while back you posted a picture of a kick "Scope Shot?", possibly from a Digital scope or SIM.  Could you tell me where it came from, or how it was generated?  Certain basic concepts of the "Kick" are slowly showing themselves in other areas and I'm trying to pull it together.  It seems that the "Original" idea of the kick being an interaction with the Earth's mag "Field" may not be very far off, as if you map the "Field" interactions that occur when "Inside" another field, well, I'm sure you get the idea.  I'm Still learning.
Thanks all.
interaction with the earth's mag field was probably a hint that the kick interacts with magnetic fields in some way, possibly ina beneficial way since SM mentioned it at all
The recent "kick" scope was captured from a HV impulse circuit.
        -Frank Edwards
forest
what if kick is th proof of something much more important , much more crazy ? what is it's current generated FROM Earth magnetic field ?
what if ANY current is the same ..... will the world be the same ?
Mk1
I think the problem is that every one that makes the discovery of the kick power has its own personal explanation, some see it as taping in the gravitational field , some see it as a vacuum , others , some as godly acts.
That is one of the reason why we don't get to work and play with the words searching for the proper explanation , or a believable one.
First isn't pure energy solid matter , in theory , so any thing should work well there doesn't seem be two much power in matter around here, well in its solid state matter looks unpromising it is undisturbed so you need to kick to see what its made from , kick to make waves , these waves are the energy released from its pure form.
You induce a kick in a magnetic core the core reaction send to kick from coil to coil, kick a large enough copper coil the coil will kick you back.
For radio emitter they kick magnetic core you get radio reception.
so you can kick pretty much anything even air , some core work better then others.
I believe nature as the real answer , this is seen in many physics experiment also , even the beers blowing bottom with one tap. the beer is filled with water you hold the bottle tight and tap  it down with the other hand (creating a kick ) so it creates air pockets at bottom of the bottle , this air pocket created by the kick generates a kick back breaking the beer bottle bottom .
That air pocket is so powerful because of is different pressure potential , the bottle breaks right off , DO NOT TRY THIS WITH BEER IS IT !! OK.lol
If its beer the energy from the kick is released in a less convenient way.
This is one way of seeing it , there are so many more .
Here is a video i found of the trick to get the picture.
http://www.break.com/usercontent/2007/4/The-Exploding-Beer-Bottle-Trick-Explained-273903.html
Grumpy
Quote from: forest on May 03, 2009, 03:49:59 PM
The "kick" is proof that conversion of energy is possible without billions of dollars - nothing more.  This is why no one who really knows will confirm that the scope shot that I posted was indeed a "kick", so I took their silence as confirmation.
It is not a magnetic field, but it interacts with magnetic fields in some way.  Keep in mind, though, that all currents create a magnetic field.
It appears that to convert the kick to useful energy, we need to add a third dimension to it, which implies forming it into a ring.
It has absolutely nothing to do with "negative resistance" or the host of other incorrect assumptions and explanations.
        -Frank Edwards
otto
Hello all,
@Grumpy
this means no Moebius in a TPU??
A Moebius gives us a negative resistance.
Otto
