Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
metatorian
To access above:  enter application #   10/954,767
http://portal.uspto.gov/external/portal/pair
and click the tab "Image File Wrapper"
also another view for the patent application:
http://www.google.com/patents/about?id=oH2bAAAAEBAJ
metatorian
Check the amended Pohlman claim 04-23-2007   CLM :
metatorian
Most of the 355 page response refers to the work of George Sparling for support:
One of the abstracts of his latest papers is a helpful summary:
Spacetime is spinorial; new dimensions are timelike
Author: George A.J. Sparling
http://arxiv.org/abs/gr-qc/0610068
Since Pythagoras of Samos and Euclid of Alexandria [1], we have
known how to express the squared distance between entities as
the sum of squares of displacements in perpendicular directions.
Since HermannMinkowski [2] and Albert Einstein [3], the squared
interval between events has acquired a new term which represents
the square of the time displacement and which comes in with a
negative sign. Most higher dimensional theories, whose aim is
to unify the physical interactions of nature, use space-like extra
dimensions (more squares with positive signs) rather than timelike
(more squares with negative signs)[4âˆ'8]. But there need be
no contradiction if timelike extra dimensions are used: for example,
in the seminal work of Lisa Randall and Raman Sundrum [8],
consistency can be achieved by replacing their parameters r,^2
and lambda by âˆ'r,^2  and âˆ'lambda, respectively. Here a new
spinorial theory of physics is developed, built on Einstein’s general
relativity [3] and using the unifying triality concept of Elie Cartan [9,10]:
the triality links space-time with two twistor spaces[9âˆ'14]. Unification
entails that space-time acquires two extra dimensions, each of which
must be time-like. The experimental device known as the Large
Hadron Collider, which is just now coming online, is expected to
put the higher-dimensional theories and this prediction in particular
to the test [15,16].
metatorian
Citation for above article: Sparling, George A. J. “Germ of a synthesis: space-time is spinorial, extra dimensions are time-like.” Proc. R. Soc. A. doi:10.1098/rspa.2007.1839.
Story at: http://www.physorg.com/news96027669.html
Mathematician suggests extra dimensions are time-like
April 17th, 2007 By Lisa Zyga
[snip]
“My work can be seen as a strong antidote to the present air of pessimism surrounding modern fundamental physics,” Sparling said. “As is well-known, string theory has been roundly criticized for its lack of predictive power. String theorists have been reduced to an absurd reliance on the anthropic principle, for example. Here I have a clear-cut prediction, which goes against the common wisdom, which gives experimenters a target to go for: first find the extra dimensions, then decide their signature (a very tough homework assignment!). Of course I could be proved wrong, but the effort to decide is surely worthwhile.
“Actually, in the area of philosophy, I am in opposition to string theory,” he said. “It is a top down theory: dream up something that works in some high dimension and then try to finagle some way of reducing to fit in with the lower-dimensional theory. My approach is bottom up: take the existing four-dimensional theory seriously and try to build up from it. This is very tough to do. Hopefully my ideas work. Note that my work only constitutes a possible beginning at a more inclusive theory.”
BEP
Quote from: otto on June 05, 2009, 05:06:57 AM
Hello all,
maybe its better to think about TPUs and not about such patents.
The TPU is not soooo complicated.
SM said its only the knowledge about how coils are working, interacting...
Then you have Tesla with his coils...
Otto
@Otto
In this puzzle one finds pieces that have the correct color pattern but do not fit. Then there are the pieces that fit but have the wrong colors.
I await your presentation of the working simplicity.
Many things attributed to SM have become true. I am at the point where strange effects can be generated. Some defy explanation by any current rules. Now, these are only good party tricks to confuse people.
This patent only demonstrates the thoughts of a typical, over-the-edge, genius. They have absolutely no creative ability except to translate, explain, validate and combine the work of many others into patterns very few can understand.
I suspect this patent examiner has an above average IQ but the theory described in the patent will never be understood by him.
Also, the theory cannot be completely correct. It suggest the possibility of time travel. In my mind time-viewing may be possible but time travel will never happen. How so? Because of my early mention of experiments using a watch and coils.
So who is correct? Was SM correct in his explanations?
Until I see some viable method of producing extra power I will continue trying pieces from other puzzles.
The attached pics are sooo unrelated to the TPU - NOT!
