Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
BEP
@MCD
I have only two disagreements with you last post.
1. If the red wires have no connection then please tell us how the have a purpose. I cannot see any possibilities without connection.
2. Your comments to Marco. If you are called a 'Tube Man' feel honored and thank him for it. I would  ;D People who only know SS are like auto drivers who can't fix a flat tire. If things reach an unknown point they must sit and wait for someone to help.
HeairBear
Quote from: BEP on June 11, 2009, 08:31:39 AM
How about an "Avramenko Plug"?
http://www.alternativkanalen.com/s-wire.htm
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
innovation_station
MAYBE I WILL MAKE A MOVE ....  :D
IF I DO IT WILL HAVE NOTHING TO DO WITH MAGNETICS AND ELECTRICS ...
FIRST I WILL EXPLAIN IT ..
TAKE A HAMMER HIT SOMETHING WITH IT ...  MAYBE A  PEICE OF STEEL  IT WILL RINGGGGGGGGGGG
SO B4 IT STOPS RINGGGGINGGGGG  DO IT AGIN IN THE CORRECT TIMEING ...
WHAT IS THE RESULT
HIT IT THEN TAP IT ....   HUMMMMMM
IS THERE A RESONANT RIZE .....  ;)
IST!
Grumpy
Quote from: BEP on June 11, 2009, 07:22:30 AM
"WHY?"
There should be no question. They are connected somewhere.
5000Hz can also mean 5000 RPM so it must be like a generator with a virtual rotor. Albeit, the 'fields' mentioned are not described as magnetic.
I hope we do too. I don't think we will if we continue thinking about moving a simple magnet over a piece of wire. That is the weakest way to cause current flow with a magnet. The strongest way is to align that magnetic field radial to the wire. Then rotate it around the wire at very high speeds.
Therefore, the 'core' is a conductor or air AND this conductor is in the center of the TPU. This conductor is created with the operation of the TPU, NOT part of the assembly.
How do you think he could measure current with the clamp meter with no wire in the clamp? Try it. I have. The only way to have a reading is with a current carrying wire inside the clamp or a large change in the local magnetic field strength (also, assumed possible if you had current flowing through air).
I think the TPU is nothing more than a means to emulate the action of magnetic fields around a current carrying wire. When running it causes current to flow through the vertical axis of the TPU.
To tap this potential he adds a Rogowski coil all around the TPU (constant voltage output) and we have confused this coil to be a control coil. The only control coils are the ones on the outside placed in quadrature positions. The FTPU and OTPU use a slightly different method.
With that thought in-mind consider this:
You CAN stack Rogowski coils on a current carrying wire. AND you CAN connect them in any method you choose to increase voltage or current output. AND you can have as many as you want.
Our terminology is wrong. The 'collector' IS the complete TPU. The loop in the middle is just the return wire for the Rogowski coil.
While the above is only my opinion I am quite certain I am correct.
Great post, BEP.
        -Frank Edwards
giantkiller
