Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
metatorian
Quote from: pauldude000 on June 11, 2009, 03:31:41 PM
All "Energy" is either locked up in and/or proceding from as well as eventually returning to, the "space-time matrix".
What we are describing is in effect the "Aether" of old. No surprise, as it requires little imagination to understand that the current space-time understanding did not ever replace the Aether concept, but merely restated it.
That is why "space-time" has physical properties to begin with. It truly no more explains action at a distance than did the old Aether concept, it merely gives finer detail.
Paul Andrulis
Hi Paul,  Followed what you said up to what we quote here,  I suppose you mean three-dimensional space-time does not explain action-at-a-distance,
...Pohlman's hyperdimensional space-time would explain action-at-a-distance, and would also relate to Bohm's Super Quantum Potential. The frequency of quintessence being related to wavelength raises some interesting questions about the topology he describes.  Thanks for going out on a limb.  ;)
BEP
Well, after last night I should correct my statement about bucking turns being the only way I know how to create radial fields. A single layer flat, spiral or pancake will create an even one. One could also call it a voice coil. The big differences are the spiral evenly distributes but has counter direction from the center to the edge comparing top to bottom.
The bucking solenoid types create a field as if a magnet was between them with one pole facing the device center.
How this applies is not clear to me yet unless I sandwich one spiral with two others and use the one as output.
So many variations.....
Create a static charge with all this and pump it round n round?
Not a good idea to take the day off to play on the bench.
I think I'm convinced now this thing has more to do with ESR than ETR, aether or any other magical terms.
MACEDONIA CD
ok now i have here  small spinig   now is time to put red wires  to  get  start my jet engine turbine   ;)
Grumpy
Quote from: BEP on June 11, 2009, 08:00:31 PM
You create the proper moving field around a conductor to create current flow.
        -Frank Edwards
BEP
Is that a kick?   ;D
Yes. Around the conductor but in two directions? One problem....
Almost half the time you are making things happen - you must keep it from happening, hence the second but lower major tone on the audio analysis of the 6" one powering a light bulb.
At least I've only had to rewind once, so far.
