Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
Antimon
Quote from: Hoppy on January 24, 2009, 01:38:39 PM
I can see that there may well be three groups three coils around the circumference of the big TPU to increase power output and these may be working at different frequencies but not necessarily creating a rotating magnetic field.
It's not possible without rotation. I haven't said which field, but we have to move it....
A.
giantkiller
Quote from: wattsup on January 24, 2009, 01:51:29 PM
@Room3327
I thought  you were referring to the rotational speed of the generator in the Tesla patent.
@sparks
I think I got exactly what you mean. Surprised?
The FTPU has a second ring coil and that explains why the winding wires had certain changes in their visual diameters when  looking real close up. The outer ring is the output converter coil and now to only make high voltage spikes, that's easy. The outputs I have already traced.
Holly shit. Next experiments. Another insulated bailing wire ring with one thin wind and one thicker wind.
GK4 right out of the 381970 patent. Just dont touch it when it is on. Keely damaged his left hand around the late 1800s. Check out the pictures of him. He hides his left hand.
--giantkiller.
turbo
Quote from: Chef on January 24, 2009, 01:56:16 PM
It was just a joke, I think you know, why I made that.  :P
I have no idea, could you please tell me?
Well i have no idea either, but sometimes that happens.
I was just wondering if you knew why.
Nevermind bro.
turbo
Quote from: Antimon on January 24, 2009, 01:56:01 PM
A.
Thanks,
This info goes for "the tip of the day"
I really hope they will drop the magnetic part some day.
sparks
     Damn it is such a simple concept a child could get it.  Take a sinewave as it appears on your scope.  Now start to shorten the time axis while maintaining in your mind what it is doing to the wave amplitude.  As you compress the time or x axis your voltage should be going up and up the screen.  When you get the x axis to reach zeropoint notice that your voltage level is now lets say off the screen off the planet and terminates at some event horizon line.  Now go the other way and you can see that the wave can expand to a great many frequencies as you lengthen the time axis.  Now shoot that time axis until your sinewave is flattened.  Now you have a dc bias of infinite wavelength.  One oscillation from o-1000 volts in a nanosecond will expand to o to how many volts in say an hour.  Not much but the current or reaction of the mass to force should be quite lengthy.
    If we use the coils of a motor as the inductor in a resonant circuit.  Within the inertial frame of the resonant lc circuit the rotation of the motor and mechanical loading of such is not there.  The motor loading resides in the inertial frame between the motor shaft and stator only.  The oscillations of the resonant circuit  therefore are undamped by the motor loading.  Einstein or someone said that all physics are the same for every inertial frame of reference.  The problem occurs when the observer has to look at two inertial frames of reference at the same time.
What laws govern the interaction of two inertial frames of reference seems to be where quantom physics falls apart.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
