Energy from gravitation
Started by Gravitator, September 05, 2008, 01:29:23 AM
Gravitator
I noticed that I had a mistake in my thinking in previous post. In this version this mistake is fixed.
At the idea level I think this might work. In real life, who knows.   :D
I speak for myself when I say I understand nothing of your drawing. You have to make it more clear, you refer to things that aren't there or are doubled please be clear if you want others to understand your thinking pattern.
Gravitator
Sorry. I try to explain it in words as actions from start point to end point.
The last post's picture describes the Start point.
1. 100 kg is 200 cm from ground and it is bound to pulley 1
2. 100 kg moves down and turns at the same time pulley 2 to the right
3. pulley two lifts first 40 kg weight up to 95 cm. At this point 100 kg is 152,5 cm from ground
4. 40 kg will be moved (eg. cannon ball will be rolled) on the shelf that is bind to pulley 3.
   Pulley 3 is locked so it wont start to rotate.
5. 100 kg will continue moving down and it start to lift second 40 kg up.
6. when second 40 kg is lifted 95 kg 100 kg is 105 cm from ground. Second weight will be moved
   to same shelf than first one.
7. After this 100 kg lifts the third (last) 40 kg 95 cm up and it will be moved to shelf
8. At this point 100 kg is on the fixed shelf which is 57,5 cm from ground and 120 kg (3x40 kg)
   is lifted on pulley 3 shelf
9. Pulley 3 will be unlock. This make the Pulley 3 (120 kg on it) turn left.
10. Pulley 3 is bind to pulley 4. Pulley 4 is little bit smaller than pulley 1.
11. Pulley 4 turns pulley 1 left. This will lift the 100 kg up. The movement goes like this
     Pulley 3 (120 kg on it) turns left
      -> pulley 3 turns pulley 4 left
         -> pulley 4 turns pulley 1 left. This will lift 100 kg up
         -> pulley 1 turns pulley 2 left. This will make the cable which lifts up 40 kg weights
            go back to ground
12. When 100 kg is back in start point (200 cm from ground) and the cable that lift 40 kg weights is
    at start point the weights will be moved back to ground from pulley 3's shelf.
13. At this point "new shelf" is turned to 80 cm and pulley 3 is locked again.
14. Now the system starts from 1 again.
Gravitator
Hi,
I have been thinking really a lot one comment in this thread: "Any easier ideas welcomed."
In attached picture is one possible solution for this.
ragnew
