Energy from gravitation
Started by Gravitator, September 05, 2008, 01:29:23 AM
Gravitator
Improved version of the same idea i had in my previous post (too early post :( ).
The idea is keep more weight all the time on other side of wheel. In this picture there is always more
weight on right side. In short the idea is following
1. Think one tire as car tire. Inside this tire there is a "rubber tire" full of water
2. This rubber tire is compressed by an other tire so that there is always more water on the other side of "rubber tire"
Marctwo
Another very interesting idea.  I like the way you think, Gravitator.
This kind of constant over balance doesn't promote movement though.  Any movement will not help the centre or gravity come closer to a neutral resting point... so it just doesn't move.
However, using rubber and water as you are may give a little chaotic instability that could help somewhat.  It'd be interesting to see this one in the flesh.
Gravitator
I was thinking too that it wont move, it is just standing water. If you divide the "rubber tier" into cells that are connected with
tube, then it might works. Below is a picture where I have added this idea.
This latest idea, I think, maps onto the "sponge wheel" which has been known for a while.
Keep them coming, though, Gravitator. You are thinking along very interesting lines, as Marctwo says.
Gravitator
"Blacksmith blower wheel" idea.
