Sphere Water Heater Large for home
Started by barrymore, September 05, 2008, 09:16:41 AM
panyuming
Quote from: Hydro-Cell on December 11, 2008, 02:43:06 PM
i also have plans to build a large heater using a 1 metre diameter sphere. that should be able to heat a house with very little or no power input.
Thanks for sharing!
I believe you succeeded in heating the ball, successful OU, so you will make a bigger one.
Thank you!
Another 15 years have passed.
panyuming
Quote from: nix85 on June 07, 2023, 04:37:43 PM
It's clearly WITTS heater, already discussed here in other places too.
https://www.youtube.com/watch?v=oZoiY3FvxKo
If the ball contains water is 1.7 gallons, it may be 6.44 (or 7.72) liters.
If the ball is full of water, it may be 14 liters.
In the video, the water temperature in the ball rises by 46 degrees Celsius (184F-101F) over a period of 2 minutes.
The current of the 9V battery = 0.18A, the power = 1.62W.
Conventional heating of 6.44 liters of water and raising it by 46 degrees Celsius requires a continuous input of 10.1kW in 2 minutes.
nix85
Quote from: panyuming on June 15, 2023, 10:10:40 PM
Duh. I shared that EXACT same calculation here years ago.
panyuming
Quote from: nix85 on June 15, 2023, 10:30:11 PM
Thanks for sharing! Very encouraging data. Apparently an OU device.
nix85
Quote from: panyuming on June 16, 2023, 12:40:05 AM
You're welcome. Encouraging data indeed. No doubt it's an OU device.
