Studying Shielding, needs some advice
Started by Originator, September 07, 2008, 10:03:01 PM
That video has way too little information to conclude that. But like I said I have seen no "active" replications at all.
The only way to know is to build it. Ofcourse if you have a magnetic neutral shield that blocks magnetic flux then that's an instant winner. I always wondered what would happen if you used this shielding on it;
http://www.youtube.com/watch?v=eo6CENdvG4c
Or to even put those directly on a wheel as is.
Originator
QuoteI think two big question arise here;
Is the attraction to the shield less powerful than the repulsion of the two magnets?
Is sliding the shield up and down through the magnetic field like that easier than you had you to make it go left and right?
When the one magnet is dead center of the 2" diameter tin circle, there is a neutral effect, it is equally attracted to all 'sides' of the tin circle.
When you move the magnet in any direction towards the tin, there is strong attraction, which will negate any benefit.  Therefor the magnet must be maintained in the center of the tin, in my opinion so far.
When both magnets are outside the tin, and within 1 inch of each other with North facing North, there is repulsion.  However when maintaining the the same distance from each other, and sliding the magnets into the tin, the repulsion 'fades'.  The magnet inside the tin must be in the center of the tin.
I need a smaller tin circle to  test with, as in this case, the magnet must be in the center of the tin to work the idea, and therefor the magnets are too far apart to get full use of the repulsive force.  Perhaps some paying around with cutting slots in the tin, or drilling holes to alter the flux may be worth a try.
Originator
Quote from: broli on September 09, 2008, 03:31:39 PM
I spent hours trying to duplicate that Youtube video already, but apparently have not done it correctly.
Some have asked the man to show a video of him creating that shield, but he has not done so.
Quote from: Originator on September 09, 2008, 03:35:00 PM
You could always try and contact him on this forum. He has his own nick and thread...
http://www.overunity.com/index.php?topic=4528.msg124474;topicseen
But as you can see at the bottom of that the story ends with an undisclosed "secret".  ::).
Paul-R
Quote from: Originator on September 07, 2008, 10:03:01 PM
Can anyone tell me if there is a material that works to  null  the effects
of two neo magnets...
You could try a curved piece of ferrous material to guide the magnetic effect out of the way:
http://www.overunity.com/index.php/topic,3979.0.html
Look for the "symmetric gradient field stator"
Paul.
