the power of rock.
Started by nitinnun, September 19, 2008, 08:23:18 PM
nitinnun
if sodium carbonate (baking soda),
is placed between copper and steel,
than voltage and amperage may be harvested from the 2 metals.
the carbon is diamagnetic.
the sodium is paramagnetic.
on another project, i have very small pieces of copper and steel, connected by a rock hard body of elmers school glue.
they still work, almost 1 year after i made them.
EVEN THOUGH THEIR GLUE, IS NOW A ROCK.
this should always work, if:
1: one metal is more diamagnetic/paramagnetic, than the other metal.
(copper and a graphite rod, work too)
2: both paramagnetic and diamagnetic elements, are connecting together the 2 metals.
3: these connecting elements are electrically non-conductive.
i have theories for why this works.
but the most important theory, is:
that diamagnetic elements have an overall clockwise spin.
allowing them to "catch/convert" the clockwise-spinning half of electricity.
and that paramagnetic elements, have an overall counter-clockwise spin.
allowing them to "catch/convert" the counter-clockwise-spinning half of electricity.
and when these 2 metals touch, the 2 spins mix, to create electricity.
nitinnun
i imagine this:
1: two metal terminals, are placed in a container.
2: the right diamagnetic/paramagnetic elements, are placed between the metals, in the container.
3: the diamagnetic/paramagnetic elements are heated at hundreds of degree's. forcing them to form into a rock.
4: this rock is chemically bonded to the 2 metals. allowing the energy process to happen, as long as the rock and metals are in tact.
my problem, is that i do not know enough about mineralogy or chemistry, to choose which elements to use.or how hot to heat it.
ideally, the connecting-rock could be made at a low temperature, out of common elements.
yet would still bond to whatever 2 metals i use as the terminals.
nitinnun
by the way.
the narrow glue-pebbles produce about 0.6 volts, at 0.3 uA.
the wider glue pebbles produce about 0.8 volts, at 1.2 uA.
remember that they are all a year old now.
the weakness, is the glues inability to bond tightly, to the metals.
infringer
hrmmm you may be on to devolpmental process of the hutchinson battery...
curious have you tried to use rochell salt between the two?
Interesting post and thanks for the info.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
nitinnun
a few years ago, i saw a video of john hutchison combining elements into a rock.
he said that the rock generated electricity, forever after.
but i didn't know what elements he used to make the rock, until now.
or even knew what his name was, or where to find his work
most of my understanding in this, comes from research which is completely independant of anything that john hutchison has done.
did john hutchinson reveal the building details of his electricity generating rock?
