You also can visit us or register at our other website at:
Keppe Motor simular to Newman-Bedini combination
Started by hartiberlin, September 20, 2008, 06:57:08 AM
khabe
Let it be. Let they fight between for "all rights" of this machine ;)
Hereby many interesting readings, when braused extending everywhere then even for all week 8)
It does not matter you are believer or sceptic - educative anyway.
http://www.phact.org/e/skeptic/newman.htm
Myself Im fervent_hope_sceptic. I hope that something must to be ... but I dont like much stupidity ... and I hate fraud.
Newman´s, Keppe... etc ... machines are interesting stuff, very interesting things but unfortunately nothing more, at any rate not OU.
Have a nice readings,
khabe
smithandwes
Anyone know where i can get the plans/description of the newman motor.  Some people say you only need one coil others say 2.  Some people are using a commutator and others a reed switch.
http://www.overunity.com/newman2 is not very useful?
A real pity about the Keppe Motor..i was hoping for something useful to build?
khabe
Seems you want to be come a rich but dont want to work ::)
is it too hard to go to -> Forum -> Newman machines -> http://www.overunity.com/index.php?board=4.0   ???
If you really want to konw about - you have to read it all.
All !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
regards,
khabe
appliedbiophysics
The Keppe Motor DIY manual [Grade D-] is a waste of money. The worst YouTube video is better than this. Shame on them... The STOP organization chants save the world mantra and like most inventors that say they want to save the world but do not share the information, some like Paul Pantone: an angel gave the knowledge to him. E-mail me for a copy of the New Keppe Motor PDF manual.
I think Joseph Newman is really amazed how this Norberto Keppe has the intellectual dishonesty to not give credit due to the sources of the people who have similar interests and ideas. Keppe motor is a Copy of the Newman Motor.
The crackpot humanist psyco-shrink babbel talk, some people suck this up like a sponge. Follow the government grant money.
Ideas are everywhere but it takes actions and effort to make anything happen. The time we have is very short in this life. Saving a condemned   world is hardly an inspiration for an idea.
oregonherbal@yahoo.com
http://sites.google.com/site/appliedbiophysicsresearch/welcome
From the PDF Keppe Motor Manual:
The Keppe Motor’s effect on a candle ï¬,ame:
Observe the movement of a candle ï¬,ame inside a longneck glass container that pro-
tects it from the wind approximately 1 meter from a Keppe Motor working at low speed.  (To
achieve low speeds use low voltage batteries).  Stop and start the motor several times and
see how the candle ï¬,ame moves in accordance with the motor’s movement, even though
the ï¬,ame is protected.
The Inï¬,uence of one Keppe Motor on another Keppe Motor
at distance:
If you put two Keppe Motors (whether identical or not) side by side and have one motor
functioning, the other will automatically begin to spin at a speed that corresponds to one of
the “harmonic resonances” of the first one, even though no external power source is in use
on it at all.
If this phenomenon does not occur immediately, it is because the speed of the first mo-
tor is too fast. Use your hand to help spin the second motor until you notice it spinning by
itself. At a certain speed it will work by itself without significantly affecting the speed of the
first one.
This experiment suggests that many Keppe Motors functioning together will create a
resonant energetic field within which each one benefits from the other, increasing each
one’s efficiency even more.
Feeding a Keppe Motor with another Keppe Motor:
When we connect two Keppe Motors, we can demonstrate that both motors working in
tandem will consume less energy than if they were working separately. This means that the
Keppe Motor is capturing energy from space. For example, when there is a series of Keppe
Motors connected by wires, the next in line will always need less energy than the previous
ones to generate the same performance.
To illustrate this, the Keppe Motor development team conducted the following experi-
ment:
We developed two similar Keppe Motorsâ€"the first one with a thicker wired coil. We
rectified the current generated by the magnet of the first motor and sent it to a 10,000 µF
70 Volt capacitor, which in turn served as a power source for the second motor.
In measuring the consumption of the motors, we verified that working together we could
produce the same work (axis speed) at less energy consumption (1.5W) than if they oper-
ated separately (2.2W). This indicates that the energy needed to make the motors work
does not come only from the battery.
Below find the data for the experiment:
Separate Motors:
Motor 1: spinning at 3,000 rpm consumed 1.5W
Motor 2: spinning at 1,000 rpm consumed 0.7W
Connecting Motor 2 to Motor 1 through a bridge rectifier and a capacitor, we found:
Motor 1 spinning at 3,000 rpm
and
Motor 2 spinning at 1,000 rpm
in operation together consumed only 1.5W
In other words, rather than the 2.2W of consumption we might expect (adding 1.5 W
and 0.7W together), the consumption by the battery stayed at 1.5W even with Motor 2
connected!
Conclusion:  There was no extra electrical energy needed to move the second motor.
So where did the energy come from to move it? Not from the battery, but from the second
component of space energyâ€"the returning or “complementation” component of the Essen-
tial Energy. This is exactly what is predicted in Keppe’s New Physics.
