Faraday's Paradox experiment
Started by scotty1, September 27, 2008, 07:20:24 PM
Grumpy
how would you create the interaction without moving all of that mass?
        -Frank Edwards
gravityblock
Quote from: Grumpy on October 28, 2009, 08:48:38 AM
LOL.  I have no idea what you're talking about.  All that is required to have a voltage for current to flow is relative motion between the disc and external circuit and for the disc  or external circuit to move through the stationary magnetic field.
The interaction with that design is no different than the interaction with a conventional HPG.  Below are the conditions for a HPG to create a voltage for current to flow.
1)  Stationary magnet, rotating disc, stationary external circuit produces a voltage and current.
2)  Stationary magnet, stationary disc, rotating external circuit produces a voltage and current.
3)  Rotating magnet, rotating disc, stationary external circuit produces a voltage and current.
4)  Rotating magnet, stationary disc, rotating external circuit produces a voltage and current.
Grumpy
Create a force perpendicular to the magnetic field and you cause particle drift perpendicular to the force and the mag field.
"Motionless homopolar generator"  ...bada bing!
Come on, GB, take a good hard look at it.
        -Frank Edwards
gravityblock
Quote from: Grumpy on October 28, 2009, 08:52:43 PM
A "Motionless homopolar generator" would be great.  I will consider giving this more thought.  I'm under the impression you feel the kick coil at 7.8hz perpendicular to the magnetic field can be used as a force to cause the electrons to move in a conductive disc, as it does with the dancing magnets in the video.  I will say this is an interesting idea.
Please note, the two dancing magnets are moving radially and not in a circular motion that occurs when the free electrons drift in a uniform magnetic field randomly.  This is due to other forces and fields being present.  Since the force is constant and perpendicular to the magnetic field, then the dancing magnets move radially.  This would suggest the current would flow radially in a conductive disc with this setup.
The interesting thing in the video, is how the dancing magnets move back and forth.  This should allow us to create a return path and have a voltage potential between the axis and rim, without having relative motion between the disc and external circuit.
Excellent Idea,
GB
Grumpy
replace the rotating disc with a rotating force field
Have you ever seen Eric Dollard's video where he demonstrates a Tesla Coil transmitter and receiver, lighting bulbs with radiant electricity, and shows that a strip of copper is "attracted" to the bulb lit by the RE?
Now, you probably can't just place a ring of RE-lit bulbs inside a toroidal coil and get the goods.  The "force" will be in all directions and according to the "guiding center" link above, the "force" has to be in one direction.  So, it may work if you pulsed your RE bulbs sequentially inside a toroid, or with a coil inside or ouside the ring of bulbs.  Don't forget the static magnetic field perpendicular to the coil.
Kind of sheds a new "light" (pun intended) on those UFO's with rotating lights...
Edit:
There may be a few other ways to impart the necessary force to the conductor:
The Resonant Gravity Field Coil paper that has been floating around since the BBS days mentions altered gravity in the center of the coils.  This device also has a static magnetic field around it - a solenoid coil - which is modulated to vary the field in the center of the coils.  Gravity is an acceptable "independent force" mentioned in Method "C" for causing particle drift.
        -Frank Edwards
