Low Cost HHO Applications!!!
Started by rogueleadr, October 04, 2008, 11:18:19 AM
Rocko
If you find a simple low cost HHO that produces 100% let us all know about it.
But in reality a simple low cost HHO will only help improve what you have with you gasoline ICE
Yes timming would have to be set atdc for "100% HHO "
as far as SS exaust goes every ICE car ever made could use one with all the water and condensation that runs thru them now
The last I knew the pistons are made of aluminum and I havent seen any of them rust. in fact most if not all cylinder heads & blocks are made of aluminum now. If you were to dump the electrolite directly into the cylinders you may have problem but I have seen nothing that would suggest the need for ceramic treating. I actually use an HHo system, i know its not 100% HHo but there would still be some signs of problems if any of that were to be the case.
Theres alot of BS out there and its hard to tell who you can believe thats why the best way is to try it yourself
Good Luck    and again if you find a simple low cost system that that will run 100% HHO let me know and build it.
rogueleadr
yeah okay, maybe your right. There is a lot of BS out there, and i'm thinking that you're right.
So, i am currently working on a Dallas Goldbug style electrolysiser, you know, the wal-mart cup one lol.
I just need to find someone with a drill press, then i'll be done. That project is after i finish my trebuchet today, cuz that one has to be done for a grade :D
If anyone has any tips for low-cost electrolysisers let us know!
Rocko
I saw that style and it looks like it works good. Just make sure your container does not leak as it will cause very poor hho production .
Also do not use baking soda its a big waste, KOH (potassium hydroxide) or NaOH (100% lye) work well. you can find them at the hardware stores with the drain cleaners.
1: build it
2: get it working at peak performance
3: then connect to the engine
good luck
GadgetMan
Hello, All!
I'm here to offer you the opportunity to help build what is becoming a great free resource site for HHO builders.
Bearing in mind our desire to share freely with all, the site is donated to me to use to share the technology we're developing, in the hope of a more rapid dev process for us all.
The site is located at ClubHHO.com. If you go now, you'll find it very much under construction. I'm in the process of organizing it this week, so there will be some MAJOR changes in the nav.
I want any of you interested in sharing or learning to come and login. I'll be sending out notices as the changes take place, all of which are intended to give us all a well-organized and dynamic place to share our ideas and to learn from others.
As the site is donated by another company, if you would just click an ad, that goes to our benefactors. Nothing is for sale at ClubHHO. It is a pure site, and it will stay that way.
Come and help me build it the way YOU want!
I am GadgetMan@ClubHHO (dot com)
Hydro-Cell
hi guys
i have read this thread and find some of these things said very interesting.
firstly a stainless steel exhaust will not be and never will be required on a hho system even 100% hho.
a efie unit should be used for optimum performance with a spacer you dont actually know what your o2 sensor is sending to the computer.
pwms are hit and miss and are really in there expermental stages as to producing major output.
retiming the engine only becomes necessary when running on 100% hho, this is due to the fact that the burn is 1000 times faster than petrol, so the timing will need to be advanced to about 27 degrees past tdc
i know this for fact as i have an engine running like this on 100% hho
ceramic coating of any parts is complete BS. When running on only hho the engine runs as clean as it did the day it was made, and since the burn is much cooler then there isnt even an heat or scorching aspect to think about.
if you require any more info then please ask
