Thanks to ALL for your help!!
Sabous Magnet Motor
Started by CLaNZeR, October 06, 2008, 04:42:20 PM
McGiver30
I dissagree with the statement that a self starter motor would continue to accelerate till it distroys it's self. In my tests it only accelerates till you have reached your maximum magnetic force, like a person peddling a bike, can only travel as fast as a person can peddle.
nightlife
McGiver30, "In my tests it only accelerates till you have reached your maximum magnetic force, like a person peddling a bike, can only travel as fast as a person can peddle."
Now think about what you just said. For your test to self start as you said, you would have had to have set the position of the starting point. A true self starting perpetual motion design would not be required to have the start position set. It would start at any position and if it self started at any position it would continue to accelerate until it self destructed.
nightlife
McGiver30, something else to remember is that the magnetic force is unlimited with out a resistance. Only when a resistance, either negative or positive, is applied to a magnetic force will you have a maximum potential of a magnetic force.
turbo
The person that is peddling a bike simply cannot go any faster because of two elements.
1.He cannot supply more energy into the system, he has reached the point of maximum output.
2.Resistance , Like the wind and the friction in the system, it will work against him, thus lowering maximum output.
Please remember that magnetic fields are stationary in space.
It is the external input action that is being converted into electricity and/or the external electricity that is being converted into motion, this is the source of the energy.
Therefore magnets alone are not able to drive something without an external element that creates a disturbance between the powering and resisting forces.
When you create a disturbance between these two elements, nature will force them back into balance.
(Gravity excluded in this simple example)
So you have to keep putting energy into the system to keep the disturbance or it will come to a state of balance again and thus it stops.
Marco.
nightlife, you don't know what you're talking about and are polluting this thread. I suggest you and the others replying would post in the thread he made.
As for the this motor. Interesting indeed, the only way to get an accurate description of the philosophy behind it is to contact the inventor.
