Isn't free communication as important as free energy?
Started by exxcomm0n, October 07, 2008, 12:10:52 AM
WilbyInebriated
black's law dictionary defines license as "The permission by competent authority to do an act which without such permission would be illegal."
so i need permission to marry, permission to drive, permission to conduct business, permission to communicate... ad infinitum ad nauseum.
so much for separation of church and state, constitutional rights to travel freely and unencumbered, etc. ad infinitum ad nauseum.
so much for freedom...
everything is important except freedom  ;)
FreeEnergy
this thread really excites me! great idea! lets push this as much as we possibly can! maybe we can own our own open source satellite network! :)
:o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o
exxcomm0n
Quote from: FreeEnergy on October 07, 2008, 04:05:14 AM
@FreeEnergy
That'd be an interesting thing, but satellites are very expensive so I don't see it happening tomorrow. ;)
@ all
After googling "tesla ground wave wireless" I found a bit of reference on the 'Net about his research and it's uses.
http://amasci.com/tesla/tmistk.html seems to think Tesla made an error in why this effect works, but not it's workability
http://www.borderlands.com/newstuff/research/teslahaa.htm battles the association between Tesla and HAARP
http://montalk.net/notes/tesla-wireless-technology posts a simplified view of the tech and way it would work (there's also a free energy tie in when it is suggested that electricity broadcast this way is able be received in the same quantity by multiple receivers
http://www.overunity.com/index.php?topic=5607.msg130062 a post here about a manufactured kit that has been dormant for a few weeks
http://www.teslatech.info/ttmagazine/v1n4/valone.htm brings up well footnoted historical evidence as to why this technology is being investigated today (well within the decade) for decreasing the losses of wire transmitted electricity
http://www.teslaradio.com/pages/wireless_102.htm tries to narrow down which transmission method may be responsible for the effect.and tightly coils it with wireless power transmission
http://milan.milanovic.org/math/srpski/tesla/tesla3.html Tesla's own writings and drawings of the effect
www.mwr.medianis.net/pdf/Vol7No2-05-AMarincic.pdf explains a bit about the tech and cites it's proof in ELF (extremely low frequency) discoveries 50 years after Tesla's claims
http://www.bibliotecapleyades.net/ciencia/esp_ciencia_tunguska02.htm is a reference to the ever infamous proposal that Tesla experimentation was the cause of the Tunguska event
http://users.beotel.net/~gmarjanovic/1Superluminal.html is a theory of spectral analysis of the transmission method with a nice graph of wavelengths
http://www.pupman.com/listarchives/2006/Apr/msg00420.html is an interesting thread discussing the difference of Hertzian waves (electromagnetic radiation) and electrical waves trying to define that difference
http://www.scribd.com/doc/2382754/Nikola-Tesla-The-Wireless-Transmission-of-Power is a paper written studying the definition of "non-Herzian waves" as described by Tesla
http://www.icehouse.net/john34/groundradio.html has a lot of information (too much for right now...that'll take a while to digest) that seems to be applicable to the topic
I have lots of reading to do to get up to speed on this.
Just throwing out some material to keep this thread going. ;)
When I stop learning, plant me.
I'm already of less use than a tree.
Magnethos
This is very corious!!!
Before starting to be interested in the free energy research, I researched in free communications. The first idea I had was writting a computer program to re-zip the files. So, a 700 Mb file could be zipped in 10 Mb or maybe less. I spent a lot of months testing and testing and finally I had an possible way to do that, but the big problem is that today computers has not capacity to do that.
My second idea was to build a simple homemade device like Wi-Fi, to communicate computers that are very far away. The problem is that no one help me in the project and I ended the project and I saved the 'theories' in a file inside my closet. But I can read what I wrote and re-start the project again.
Magnethos
The compression Technique (First Idea)
You know that common comressor like winrar, winzip, etc... use a low efficient algorythm to compress a file. If you have
000001111100000111110101010101000110 then the program do:
0x5;1x6;0x5;1x5... to compress the file. I think that technique is called run-length method. There are other techniques, but no more effectives. That works when you have a low-entropy file (non chaotic data), but when you have a high entropy file like... 0011010011100001110000101010111010000111001011000101011001010 the compression program can't do miracles with the file.
My compression technique works in this fashion:
You have the file (low or high entropy file) then, you extract the Key Data (a critical information to re-construct the file) and you only have to store the Key Data to re-build the file later. The idea is to extract patterns from the file, a very specific patterns, to identify and build the original file, so using this technique you don't need to have the original data of the file because you only have its patterns. In the picture, you can see better the process.
First, you have the original file. A film for example.
Original Size: 701,345 Kbytes
Then, you create a minifiles because the amount of combinations and patterns of a 701,345 Kbytes file is almost infinite, so you have to work with little files. For example... 5000 Byte files. When you have that 5000 Byte file, then you put inside a specific data to make easiest the re-build of the file. This is made because when the program re-builds the file is easy to check if the result is the correct file, because the program can look for that specific data to check if the file built is the desired one. This step is important because the program can generate a file that has the same patterns of the original file, but the built file could be incorrect, so if you check for that Key Data is easiest to identify the correct file. Before this step you have extracted the amount of each byte of the minifile.
Example:
Byte 0: 155
Byte 1: 34
Byte 255: 54
The next step is to extract more patterns. In this process there are 2 steps, the first one is to identify the patterns of the Minifile+KeyData file. The program extracts the patterns of that Minifile+KeyData file and then the program extracts the patterns of the encrypted Minifile+KD file. So, the program encrypts the Minifile+KD and extracts more patterns. The program repeats this operation with the rest of minifiles until the program has completed the 701,345 Kbytes. When all is finished, then you merge the minifiles to create only one file. Then, you can repeat the same process to re-compress the file again.
OF COURSE, THERE IS A LIMIT IN THE NUMBER OF TIMES YOU CAN RE-COMPRESS A FILE. I DON'T KNOW THE EXACTLY AMOUNT, BUT YOU CAN'T RECOMPRESS THE FILE AGAIN AND AGAIN. THERE IS A LIMIT, BUT I WANT TO SHOW THAT THIS TECHNOLOGY IS HIGH EFFECTIVE IF WE COMPARE IT WITH THE COMMON COMPRESSION TECHNOLOGY.
