Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
forest
The answer surely is in question : can we duplicate electric signal having at the end two of them of twice the initial energy ?
The answer as I was told is : NO,we can't.
There are only two possibilities :
1. There is a way to do this with electric power. The only candidate I can think of is parametric oscillator.
2. There is no way to do this , but we can do this with magnetic current because it DOESN'T FOLLOW OHM LAW
echo is the answer but such kind which is an exact copy of source
Can we do this with electric current or electromagnetic field ?
Tito L. Oracion
Quote from: sparks on January 28, 2010, 12:23:48 AM
  Why a rotating magnetic field.  You can produce a rotating magnetic field simply by taking an input=and splitting it into two circuits.  Two windings with matched impedance but in series resonance with different capacitors arranged around an annular or laminated ring will get you a rotating magnetic field.  The frequency of the oscillation  (a rotation is just an oscillation gone over the top) or speed of the rotating polarization of space dependent on the pulse train from the power scource.
actually if we add a little current in the rotating magnetic field, it makes a very big difference in the device, its like a triode vacuum tube effect.
@all
you know what? there is no more secret here anymore, the only thing that is not reveal here is the arrangement and the process detail ok!.
all components are already said. amazing  ;D
i think FLOYD SWEET device info will help more ok.
sparks
    The power to get the system ringing is input at one rate.  This creates times when a very high charge seperation occurs or a very screwed up magnetic flux density occurs.  The rest of the scources that create the ambient field conditions for these parameters respond to the standing wave.  When the reactive power in a system is extended so that you are in the system then the reactive power becomes real power.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
baroutologos
Sparks, you even understand what you are saying man?
forest
There are many ways to skin the cat but cat remains the same and the result is the same.
