Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
baroutologos
No, i think we are all missing the point here.
From numerous experiments it can more or less safely concluded that the energy magnification is not inside resonance alone. As Tito suggests it must comes from somewhere.
The less mystique the source, the more propable to be real :) and we should built equipment to tap that energy. Perhaps as i stated, telluric currents, in their feeble distirbances act more or less as signals send by an enormous Tesla coil sender.
Perhaps, all we have to do is to tune our apparatus to a particular frequency, "tunnel" them via resonance to an oscillator and tap them.
forest
Quote from: sparks on February 14, 2010, 07:47:25 AM
     Would conversion of a very high frequency like say microwave to  elf  or even lower be considered a magnification process.  You take infrared and change it into a lower frequency I betya the wavelength is magnified along with the amplitude.   The higher the frequency the more power of the wave train.  Why are we always looking to increase frequency which uses power when we should be decreasing frequency to get power.  Gotta go.
Yeah.You found one of the way.Oscillator of high frequency running in magnifying mode with accumulated energy of let say 50kW in peak. At peak we broke circuit for a moment at the slow rate (60hz for example) draining low 5kW output, then swing is rebalanced.
The mode of operation of Kapanadze device.
sirmikey1
baroutologos, all...
Lidmotor just bangs the two pans together to start oscillation/resonance.
http://www.youtube.com/watch?v=2Rzw4FRovnI
He's using an avramenko plug on the LEDs..
Mikey
pese
Think about it
MSA06 is not an normal npn transistor
its an darlington-.transistor
If you will use darlington configorates singel transitors use 2 pieces
of bc 107 2n2926 enz (100ma Types)
if you short the 2 alu to start.
an singel transistor break . an darlington if you use higher battery voltages. give attentention . use an resistor about 50k ohms in serie from base to the alu-tab.
Pese
http://www.stormloader.com/users/gpese/OU/
sirmikey1
Pese,
   The germanium transistor only needs .3v to run instead of .84v.  Everyone is recommending a PNP 2N1308
Mikey...
