Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
forest
Magluvin
Are you electronic engineer ? Can you clear one problem for me ? Is there really only one resonance in electronics ? (I do not mean parallel and series modes) . I have a friend of mine which is good EE for years and he states there is only one electric resonance but I think there are two kinds and the kind which Tesla used he called "resonant rise" , we call them parametric resonance and my friend told me that this is the same as normal resonance with stable resonant frequency just here frequency changes.
In other ways he said that parametric resonance is nothing more then normal resonance and have no additional features and we can "break"   such parametric resonance into stages of normal resonances with different frequencies. I have told him that such resonance is more then the sum of stages.
My most important question : if you have the normal resonance (LC circuit) ,does it really amplify (or accumulate) energy ? if you say yes then answer next question : if such circuit running normal LC at resonant frequency is broken at the point when all circuit energy is stored in coil magnetic field , what is the energy of generated impulse ? does it exceed energy of peak impulse from power source driving circuit ? do you know equations to show total energy in resonant LC circuit ?does it depend on time ?
Tito L. Oracion
Quote from: Magluvin on February 22, 2010, 07:11:55 AM
Na Teets. This bike uses a brush less motor in the front wheel. Your at 25 mph in less than 10 seconds. And the bike and me are 300lb. No gears here. The motor has like 60 1.5in x 1/2in. x 1/8in. mags on the outer drum and the coils are stationary to the hub. A lot of the pulse motor stuff we work on, we should be just be using this and modifying.
The max power in the US is 750W and 20mph to still remain a bike by law, except cali where they allow 30mph and faster with registration and tag.
At 500w I am getting very good power for up to 20 mi. depending on the stops and go's. Acceleration takes the most out of it, once going its not using 500w at full speed and throttle.
But it would be cool to be able to go and go and go. The bike has been very reliable, rain and all. I have 3 of them and 2 cars. But I ride the bikes a lot.
In fact I could make a different controller that paused a bit between pulses and capture some bemf. It could add to the ride being that the bemf is only discarded normally. Might loose some power with pauses, but the power I would get would go further.
Mags
WOW! COOL!, This is interesting. i like it!  ;D
you gave me an idea to work on again ha!ha!ha!
Magluvin
Forest, Im on the same trail my friend.
Check this out.
http://www.falstad.com/circuit/
Download the zip for the applet and run it from the folder you extract to. Its very good for quick circuit designs. I have made some rc rlc combos that the resonance rises very easy with short pulse, oh yeah it has a good supply of sig gens and oscope to look at many things at once.  Its helped me a lot.
But on the rising resonances, there are times that you get it to rise itself. =] The values of the L and C are infinite. But if you try to take from the rise, it will diminish quickly, so dont take it all at once and let it rise again. Im working on it. Ill show the goods when I get there. I cannot say the sim is perfect, but im impressed.
Other sims also
http://www.falstad.com/mathphysics.html
But yeah I think that a combo of coils and caps can produce more out than in if tuned properly. Im working on getting feedback from the circuit to pulse itself at the right times. Great lil sim. Up in the tabs there are many programed circuits to fiddle to your hears content, or start from scratch.  And if the writer has it running good and no off subroutines that keep us away from the good stuff happening, it just may be a good workbench to test things with.  =]
Mags
forest
I think that in normal resonance we can amplify voltage or amperage but not both.This is why I state the releasing energy is no higher then the impulse from power supply.It can be huge voltage but tiny current or huge current but a microvolts but still then ENERGY IS NOT GAINED. What Tito is saying about is something which rise exponentially like a snow ball (the bigger it is the more snow it collects). Funny thing : there is  now an advertising here on TV channel which uses parallel of snow ball to explain  new bank service : the bigger amount you have in account the more you earn each time due to percentages.
Can you spot on which video Don Smith is showing us that resonant rise graph ?
Magluvin
Teets
I put the bike together with a motor kit I got on ebay. Comes with motor wheel, controler, throttle, lead batteries 48v and new brake handles with shutdown when braking sensors. Was about $600 shipped from canada to Fl.
They have a lot of kits to choose from. Even 1000w and 2000w up to 45mph.  But I think over 30 on a bike is pretty dangerous, being that they were not meant for it in the first place and the extra weight bares down on the bike at those speeds let alone 25mph, which is still not normal continuous speed. Minimum bike for the kit I have would be in the 400 to 500 dollar range to ensure it will go a long way before break down, Broken spokes or cracked frame.
Its a great investment.
Hey no comment on the tesla bike picture?  =]
Mags
