Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
Magluvin
I looked at some hendershot drawings and this guy is rewinding capacitors. makes me think if the common values of capacitors are those values on purpose, as to not enable a proper value easily with what is out there. Im probably just babbling and a tuning cap will work.
In a schematic if you look at how the input and output are connected to the rest of the mirror image looking circuit, the ins and outs seem to be mixed in the circuit, as to do things out of phase with the single pulse from the buzzer oscillator to each side at the same time to get things going.
And the little lc circuit on the secondary of the transformers all by it self looks like the oscilation keeper or timing control of circuit after the pulse.
Very interesting. A bit wide as in how many things are going on. Be one heck of a tuning venture.
Mags
forest
I wonder if somebody saw Tesla coil like I  see it now. Primary is a coil ,secondary is a magnetic CORE.That would explain why Tesla put a visible iron core into his transformer patent.Could it be a clue?
That would also explain famous mass relation : Tesla apparently wanted full saturation of core/secondary.
Back to Edison etheric force.Not sure how it all relates but it's interesting indeed.
Magluvin
I believe Tesla believed the energy was on the surface of the coils, not in the wire itself. I have to go back and read it, but the amount of voltage in the coil was according to its length whether the wires were many fine or fewer thick. Im tired I have to sleep. Will reread this tomorrow and see if im nuts or not. =]  But maybe the can capacitor captures that energy from the outside of the coil, or the inside, i dunno.   lol
Mags
Magluvin
Hey Loner
Well back in Pittsburgh, we call it skin effect. =]
Or is there 2 out of wire energies?  I do custom car audio and on the tweets I use wire with the finest strands, to have more skin.
Does it not play by the same rules as normal conductivity?  Hmmm
Mags
otto
Hello all,
@Loner
pulsed coils are a little bit hard to understand and to explain because the particles have their rules, to say so.
On the surface of a wire we have energized particles. But not only on the surface of the pulsed wires. Particles are all around such a pulsed coil. Of course, if the pulsating frequency is higher then you have much more energized particles.
The current that is spent and that you can measure from your power supply is the current needed to move this particles and to energize them.
And yes, if you want only to pulse a coil to "produce" kicks you dont need almost no current but in such a case you cant have energized particles. On the other hand it should be possible to collect such not energized particles so we could use them. Bearden.
Otto
