Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
Magluvin
I have looked for much info in the last year and tries some things. Here is a vid i did a while back.
http://www.youtube.com/watch?v=fIreSheNujQ
As for the flat coils, maybe that is what you have on the shelf, from Teslas pat at the beginning of this thread, I see the coil surrounding the outer edge. its possible that the flat coils field is concentrated at the outer edge of the coil. But it just may be a transformer. I will see what I can do to see what is going on there.
I have not tried much in this yet. I made tiny flat coil in the vid above to test for Lenz effect for a friend, but not much going on there.
Tks vid though, i dont think you will ever see a configuration like what he shows. That is why I dont think he intentionally meant to show the goods on this stuff.
If you have seen a bedini bifi, 1 coil is just for pickup signal and doesnt have anything to do with the other coil directly other than providing timing signal to the circuit. So no bifi glory there.
Mags
delboy
Hi everyone,
I noticed that you are not talking about Tesla's Magnifying Transmitter, but you got something else to talk about :D
Anybody reading Tesla patents?
OK , here are some qustions for you :
1. Why is ignition coil build on that way it is today in our cars , but not like Tesla said it should be? (pat. 609250)
2. Why is lightning protector still build like rod but not like Tesla said (pat. 1266175)
3. Why one-phase motor (pat.464666) like Tesla designed is no where to  buy or find?
These are just some patents that are dealing with "secret" Tesla technology and you are asking yourselves where is Tesla's Magnifying Transmitter secret? Well try reading Colorado Spring Notes, than you may find out :D
Best regards ;)
baroutologos
@Mag,
I am familiar with Bedini's use of biffilar. This is not in the spirit of Tesla's patent in any way. As you correctly said, it just for signalling.
Anyone who has some knowledge in the electrotechnics, and have read the patent "coil for electromagnets" two things could think about the biffilar coil.
1)st It's a coil, specially suited for electromagnets, having superior performance in same way than ordinary ones, and likes especially to work under great voltage. (the greater the more striking the biffilar effect
2)nd It's a coil, specially made for resonance setups (in electromagnets) without having to deal with capacitors.
Is there any thing from the above, that makes the Biffilar coil, suited for "energy receiver" as tito says?
Tinsel Koala's video shows clearly that this coil sux for receiver or at least as resonator. by the way, Tinsel Koala did not showed if the biffilar is better as electromagnet (under same setups) than the normal coil.
I guess we have to find out
baroutologos
Lets suppose we place the biffilar as a receiver as tito suggests.
What would be the topology between receiver and a load?
Tito have mentioned that  biffilar coil developes a strong magnetic field. At least stronger than a similar normal coil's does. Magnetic field is energy, So biffilar is energy creator? nah...
We know that magnetic's field strength depends on the square of the current that flow in it. So, i speculate with a specific amount of charge (say a Coulomb) and given EMF, the biffilar design excells at magnetic field creation, because it shows inductunce (canceled actually) and makes larger current movement in it?????
Cannot be such simple that a biffilar is a magnetic amplifier...
In any way, how we connect the load? We have to have another "pickup" coil next to the biffilar i guess. Tito said he used a trifilar. So a biffilar + normal one coupled closely together perhaps? (hence triffilar?)
