Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
baroutologos
I do not want to be a spoiler here, but this Tesla patent is the predecessor of the plasma ignition in contemporary gas machines.
The concept is simple and is Bedini style as we know it today (Tesla style actually). Same as the ozone patent of Tesla's. Charging an inductor and then, when abruptly opens the circuit, magnetic field collapses and charges a capacitor - the infamous flyback current - .
Then, a charged capacitor in series with a coil, does what it does best. it rings at that particular frequency of the system.
The L2 coil will ring also, and if tuned will be a nice tesla coil or ringing LC. If not tuned at least will spark.
What is the advantage of it, in comparison to spark-gaps and HV generators? (apart from the noise and simpler setup?)
Magluvin
Logos
hows it goin buddy, bust out the bifi.
I made a new thread on this pat.  the thing with this is it is not freq dependent. The freq is dictated by the application needs. this simplifies things even further. Imagine, no spark gaps, simple anytime you want pulses any freq.   These things are very favorable in my book.
magluvin
Magluvin
I have to look for this 1 item first and if Im correct, Grandma can build this thing with knitting needles and a soldering iron after a trip to radio shack.
let me check this out.  be back in a bit. hold on, someones knocking on my door really loud.    BAAHH hahahaha  lol
Magluvin
delboy
Quote from: baroutologos on February 28, 2010, 04:45:04 PM
@Del boy,
I am familiar with Tesla Coils actual designs. This way Tesla achieved Qs of tens of thousands. So? You have a million volts... you have more power out? You have also a great current displacement... You have power?
Who told you that? Any proof? We are all speculating here
I'm not speculating !!! Tesla told me ;)
It's problem in understanding of REACTIVE POWER AND ENERGY !!! Tesla Coil is generator of REACTIVE POWER!
Huge POWER GENERATOR. All you need is right receiver for that kind of transmiter. And even that Tesla gave to us, but nobody wants to read. But again , problem is that we don't have correct TeslaCoil like Tesla said it should be!
quote : "In 1900, however, after I had evolved a wireless transmitter which enabled me to obtain electro-magnetic activities of many millions of horse-power"
Another quote : "In my first efforts, of course I simply contemplated to disturb effectively the earth, sufficiently to operate instruments. Well, you know you must first learn how to walk before you can fly. As I perfected my apparatus, I saw clearly that I can recover, of that energy which goes in all directions, a large amount, for the simple reason that in the system I have devised, once that current got into the earth it had no chance of escaping, because my frequency was low; hence, the electro-magnetic radiation was low. The potential, the electric potential, is like temperature. We might as well call potential electric temperature. The earth is a vast body. The potential differences in the earth are small, radiation is very small. Therefore, if I pass my current into the earth, the energy of the current is stored there as electromagnetic momentum of the vibrations and is not consumed until I put a receiver at a distance, when it will begin to draw the energy and it will go to that point and nowhere else
Suppose that the earth were an elastic bag filled with water. My transmitter is equivalent to a pump. I put it on a point of the globe, and work my little piston so as to create a disturbance of that water. If the piston moves slowly, so that the time is long enough for the disturbance to spread over the globe, then what will be the result of my working this pump? The result will be that the bag will expand and contract rhythmically with the motions of the piston, you see. So that, at any point of that bag, there will be a rhythmical movement due to the pulsations of the pump.
That is only, however, when the period is long. If I were to work this pump very rapidly, then I would create impulses, and the ripples would spread in circles over the surface of the globe. The globe will no longer expand and contract in its entirety, but it will be subject to these outgoing, rippling waves.
Remember, now, that the water is incompressible, that the bag is perfectly elastic, that there are no hysteretic losses in the bag due to these expansions and contractions; and remember also, that there is a vacuum, in infinite space, so that the energy cannot be lost in waves of sound. Then, if I put at a distant point another little pump, and tune it to the rhythmical pulses of the pump at the central plant, I will excite strong vibrations and will recover power from them, sufficient to operate a receiver. But, if I have no pump there to receive these oscillations, if there is nowhere a place where this elastic energy is transferred into frictional energy (we always use in our devices frictional energy -- everything is lost through friction), then there is no loss, and if I have a plant of 1,000 horsepower and I operate it to full capacity, that plant does not take power, it runs idle, exactly as the plant at Niagara. If I do not put any motors or any lamps on the circuit, the plant runs idle. There is a 5,000 horsepower turbine going, but no power is supplied to the turbine except such power as is necessary to overcome the frictional losses.
Now the vast difference between the scheme of radio engineers and my scheme is this. If you generate electromagnetic waves with a plant of 1,000 horsepower, you are using 1,000 horsepower right along -- whether there is any receiving being done or not. You have to supply this 1,000 horsepower, exactly as you have to supply coal to keep your stove going, or else no heat goes out. That is the vast difference. In my case, I conserve the energy; in the other case, the energy is all lost"
delboy
Quote from: Magluvin on March 01, 2010, 01:47:57 AM
I give Delboy All the credit for the presentation of the idea of where to look. I am only relaying what I read and interpreted from what I have read from other tesla patents and the connection is clear and evident.
It is the low voltage way I have had my mind set on with moving forward on this idea of amplification. It simplifies many things that are not easy to accomplish when you visualize these ideas in other patents on the subjects of..
1 simple source of high tention
2 avoiding spark gaps and quenching
3 producing abrupt discharge by way of simple switching
Of which are what becomes seemingly huge objectives when first looked upon in other patents and descriptions. This Pat provides very simple ways of doing these things, as that anyone can achieve the objective.
Magluvin
If you want to power TC with low voltage than you will use this one with two stage amplification. Take a look at this picture I posted.
But if you have source of high tension than you will use one-stage amplification. Next picture.
