Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
delboy
Just look Tesla patents hronologicaly. Tesla patented 9 forms of circut controllers = switch ! That was what he was trying to perfect.
First there was spark gaps, than rotary spark gap, than rotary switch with brushes, and finally rotating switch with liquid metal! All that was because reducing looses on commutation!!!
Where you can find switch with caracteristics 1000A and voltage drop less than 1V ???? Max you can have is IGBT of 1000A and 4,5V and that is big looses. Tesla had better switch 100 years ago, and you don't even read his patents , that is shame :(
You are still using old shema from 1891. that Tesla abandon! He perfected his own TeslaCoil and you even didn't look at it. That it is shame :(
forest
The main advantage of igniter patent and ozone patent is this : IT IS DC SYSTEM
This produce radiant effect easily.
Please tell me more about bifilar coils. Where can I find how magnetic field of this coil looks like and if inductance of this coil is stable or depends on some factors ?
Basically if I good understand any capacitor discharge into coil produce such magnetic field spike which can produce current spike in envinronment or second coil.Bifilar would just store 2500 more energy then ordinary coil which is set for one resonant frequency.
BUT..... in igniter patent there is commutator used to discharging and charging capacitor.The main problem is to build one or to replace it with electronic part ? I think solid state device would be hard to realize.
Magluvin
hey Forest
Well this is what i like about this pat. Pulse when needed. We are not tuned to any particular freq. No tuning.
If there is Radiant energy here, it will happen in 1 pulse or as many and how ever fast as you like.
I see a relay contact working fine here.   We are starting with 12v, use a relay to put 12v across the inductor, release the relay and the inductor discharges to the cap, and a relay to discharge the cap into the primary. These 2 things can be done with 1 spdt relay. Its just what is the output and what to do with it and how.  ;)
Im still looking for the door knob that I mentioned earlier. Reading and posting and reading and posting.  ok  back to reading..
mags
forest
Quote from: delboy on March 01, 2010, 02:55:43 AM
I'm not speculating !!! Tesla told me ;)
It's problem in understanding of REACTIVE POWER AND ENERGY !!! Tesla Coil is generator of REACTIVE POWER!
Huge POWER GENERATOR. All you need is right receiver for that kind of transmiter. And even that Tesla gave to us, but nobody wants to read. But again , problem is that we don't have correct TeslaCoil like Tesla said it should be!
quote : "In 1900, however, after I had evolved a wireless transmitter which enabled me to obtain electro-magnetic activities of many millions of horse-power"
Another quote : "In my first efforts, of course I simply contemplated to disturb effectively the earth, sufficiently to operate instruments. Well, you know you must first learn how to walk before you can fly. As I perfected my apparatus, I saw clearly that I can recover, of that energy which goes in all directions, a large amount, for the simple reason that in the system I have devised, once that current got into the earth it had no chance of escaping, because my frequency was low; hence, the electro-magnetic radiation was low. The potential, the electric potential, is like temperature. We might as well call potential electric temperature. The earth is a vast body. The potential differences in the earth are small, radiation is very small. Therefore, if I pass my current into the earth, the energy of the current is stored there as electromagnetic momentum of the vibrations and is not consumed until I put a receiver at a distance, when it will begin to draw the energy and it will go to that point and nowhere else
Suppose that the earth were an elastic bag filled with water. My transmitter is equivalent to a pump. I put it on a point of the globe, and work my little piston so as to create a disturbance of that water. If the piston moves slowly, so that the time is long enough for the disturbance to spread over the globe, then what will be the result of my working this pump? The result will be that the bag will expand and contract rhythmically with the motions of the piston, you see. So that, at any point of that bag, there will be a rhythmical movement due to the pulsations of the pump.
That is only, however, when the period is long. If I were to work this pump very rapidly, then I would create impulses, and the ripples would spread in circles over the surface of the globe. The globe will no longer expand and contract in its entirety, but it will be subject to these outgoing, rippling waves.
Remember, now, that the water is incompressible, that the bag is perfectly elastic, that there are no hysteretic losses in the bag due to these expansions and contractions; and remember also, that there is a vacuum, in infinite space, so that the energy cannot be lost in waves of sound. Then, if I put at a distant point another little pump, and tune it to the rhythmical pulses of the pump at the central plant, I will excite strong vibrations and will recover power from them, sufficient to operate a receiver. But, if I have no pump there to receive these oscillations, if there is nowhere a place where this elastic energy is transferred into frictional energy (we always use in our devices frictional energy -- everything is lost through friction), then there is no loss, and if I have a plant of 1,000 horsepower and I operate it to full capacity, that plant does not take power, it runs idle, exactly as the plant at Niagara. If I do not put any motors or any lamps on the circuit, the plant runs idle. There is a 5,000 horsepower turbine going, but no power is supplied to the turbine except such power as is necessary to overcome the frictional losses.
Now the vast difference between the scheme of radio engineers and my scheme is this. If you generate electromagnetic waves with a plant of 1,000 horsepower, you are using 1,000 horsepower right along -- whether there is any receiving being done or not. You have to supply this 1,000 horsepower, exactly as you have to supply coal to keep your stove going, or else no heat goes out. That is the vast difference. In my case, I conserve the energy; in the other case, the energy is all lost"
Oh,delboy. This is not so simple. Tesla was hiding a lot of information (or those were wiped from his text) - the only tip we can find is in 1900 article about increasing human energy.What Tesla described above is wireless transmission which is never OU.The piston on receiver cause a friction to be propagated back and affect piston-transmitter in the same way as Lenz law affect transformer.
P.S. I mean OU is not in such wireless transmission.It could be "generated" in transmitter alone or "receiver" alone or in DC wireless :-)
delboy
Quote from: forest on March 01, 2010, 03:34:06 AM
It is not point that advantage is DC system!
It's point that you don't produce current spikes of hundreds of ampere to produce voltage spikes on sekondary !!! Current from source is limited with H (large input inductivity) and as soon current start developing it is abruptly stoped by switch and HIGH VOLTAGE is generated on SWITCH because of III Newton law= reaction of system, and that high voltage is used to charge capacitor! Tesla's system don't give BIG load to battery!
H is large inductivity or we can think of that as model of constant current.
You are mislead by opinion that inductivity gives HIGH VOLTAGE. It's switch that regulates how big this voltage will be!!! And also it can be regulated over inductivity, look at patent no. 568178 there you have 4 ways of regulation! That is first step in amplification. Second amplification is in secondary by adjustment of primary inductivity to hit the resonance in secondary! Q factor in secondary gives how big voltage will be on TOP-LOAD!
Formula for power in secondary is P=Cs*fs*Us^2
Cs-top-load capacity for example 150pF
fs - resonant frequency in secondar for example 50kHz
Us - voltage on top load for example 1MV
Than we have P =7,5MW oscillating reactive power in secondar available for transfer
But there are more requirements to this Tesla system :D
-secondary in spiral form
-length of secondary is quater of wave length
-frequency of secondary about 50kHz (and not 1MHZ !!)
-and more...
