Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
Mr. Teslonian
Quote from: Tito L. Oracion on January 22, 2010, 09:47:13 PM
hi mags
ok, currently i only have 1000 watts inverter because that is all i can afford now, my source is an antenna, i'm using #### stage amplification, using a lot of transformer that are readily available in the market cause i'm too lazy to wind ok, the many the transformer the higher inverter watts you have is the power you can produce its unlimited ok.  a half meter by a half meter is enough for the space for a thousand watts.
i think this is my last post. i am not anymore interested in this forum ok
i'll just be watching from now on ok.
ps: no noise ok i've solved that by putting it inside of an aquarium funny but effective, i think oil is much better  ;D
did you see an aquarium based on oil. lol hahahahahaha  ;D  ;D  ;D  ;D
Please decode this one.
Mr. Teslonian
Quote from: sparks on January 22, 2010, 10:02:16 PM
      I think if we take little impulses and put them into a resonant tank each little impulse is stored in the tank.  It does not leave this machine.  The whole tank is an energy storer upper.  Proper phasing of the input is critical. This way a very small charge driven current can soon become a very powerful current INSIDE THE OSCILLATOR.
   If the lower frequency output from the tank is imposed on a tank that recognises the lowerfrequency discharge as an impulse then this second stage oscillator does what the first one did.  Pretty soon you can have such a lowfrequency high amplitude output that it starts to look like a flat wave and your bias level is way up there.  Like thousands of volts overground up there.
Dear Mr Spark and other respected members,
Just in case you are still on the forum. Can you please post such a circuit which can self oscillate and via feedback mechanism to the antenna, it can increase the amplitude many times.
Can we use a Bazooka antenna used by ham radio operators to harvest the 5000 hz hiss at low altitudes always present in the atmosphere ?
Very many thanks in advance.
---- Mr. Teslonian
