Tesla's Switch (Self/Radiant Charging Switching Batteries)
Started by sirmikey1, October 07, 2008, 10:50:26 PM
sirmikey1
Tesla Switch is an unpatented invention which was revealed from one of his associates.
Was used to power Tesla's Electric car, and his associate's.  Self Charging Battery
array which never needs charging, and caution needed with overcharging.  Appears that
load/pull/vacuum from one battery is used to charge other batteries, works similar to back
emf, where collapse/vacuum charges other batteries
Scroll down to Tesla's Switch
http://peswiki.com/index.php/Tesla_switch
SM
tak22
Thaelin
Hi SirMikey:
   I will have to bring your attention to the two caps in the bottom of the circuit. If these
are left as is, on one half of the cycle each will be reverse polorized and not be good. In
the last circuit I saw they were electrolytic and thus not workable. If left in and non polorized
you have a drop in voltage to the output. I could only see about 2 volts output with them in.
  If you remove them then you get the full output to the load. That is where I went with mine.I
also removed all the diodes and just added another transistor wired in reverse to the other one
so when you cycle, one turns on and the other turns off.
   I was trying to find the other thread where I was going to post my circuit but cant find it now.
Would it be ok to share it here? I think this is best as the topic is specificly for the switch.
I also want to caution that in one of the diagrams on the net, the FWBR is shown wrong so
if you wire up your own, use the right layout. Or just use one made up.
   I use circuit maker and there is a trick to copy the clipboard to paint and save as a giff. Know
how to do that? That way I can make up a neat and readable circuit to share. Not a hand drawn
mess like I have now.
thaelin
sirmikey1
thaelin,
  Please post your circuit and schematic and/or demo clips.
  My own thinking is that the rapid switching of the batteries
while under load creates some sort of bouncing or recoiling
effect, which is stronger than the battery, thus charges the
battery.  The recoil (backstroke) from used battery charges
unloaded battery.  Is this correct?
  Tak22, thanks for the link references to former. Do old threads
just disappear from the forum listing?  Under Tesla, I only get
49 topics.   What is going on with that?
SM
nul-points
hi all
i think this may be the thread you're thinking of, Thaelin
  http://www.overunity.com/index.php?topic=3316.0
it covers quite a few varied attempts and discussions about this particular device and the underlying principles
i found the thread in it's later stages when i joined the forum with details of my own tests - there is an overlap in the approaches: switching energy from one source to another, shuttling it back & forth thro' a load, one or more times, to increase efficiency
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
