Dry Cell goes to Austria
Started by woodpecker, October 09, 2008, 07:29:04 AM
woodpecker
@AlanA, thanks for your Comments and Questions, and keep in mind, I am not a Specialist in these things, just a curios person seeking for my own answers, I can speak only about my own experience.
The cell consumes very little. You can count more per day or week, then per hour.
Now, what can we do with the gas,what is this cell good for? Please have a look at:
http://www.panaceauniversity.org/
go down the page there and download the file: Hydroxy Booster technology (PDF) - updated October 7 2008 there you will find all the answers. These are really good people doing serious work.
vonwolf
 woodpecker;
  That is one nice designe thanks for sharing it.
  Oh Ya crazyenergy;
   a very good job  at Hijacking woodpeckers hard work and thread to get a little advertizing in, some one need to ban this guy
woodpecker
Hi all, I am back again, with some interesting Results:
During the last two days i try ed to improve my cell, i added two more plates and made better powerconnections to the plates, cause they where getting hot before. Now, the powerconnections work fine, but i had to remove the two extra plates. So i work with 10 cells and 24 - 24,5V again. Altough, theoretically the device should work with more efficiency with two more cells, it did`NT work at all that way. The cell was connected to the power for over 8 hours constantly and the Amperage did`NT get higher at all. 400mA was the maximum and it did`NT really help to add more KOH.Gasproduction very low, efficiency very low. As soon as i removed the two plates, the baby worked as perfectly as before. The Amperage now raises from 2,8A in 30 min to nearly 10 Amps. This is a little bit to quick but due to the higher KOH concentration i have in my reservoir now. I have just to lower the concentration to stabilize.
Of curse, i payed attention to jdcmusicman`s objection,that maybe my Amp meter is making wrong readings. So i went quickly buying a new one, to make sure, that the readings are correct.My new Amp meter is the type that professionals use in theyr daily work and has high accuracy now. And what shall i say - he was partly wright. Partly, because up to 6 - 7 Amps the readings where both the same, but when i am getting towards 10 Amps, the old one showed up about 1 Amp less. This could make a difference.
This morning i got up very early equipped with my new Amp meter and made some measurements:
I measured first the produced ml, it was 1 liter in 27 sek.
then i measured the Amps and i tuck the highest Value i could read. You know, when measuring Amps, when first touching the Electrode there is a Pique and the next few sek. the Amperage drops to a lower value.  I tuck the pique value, which was not favorable at all to my measurement, but anyway. It was 9,4 Amps.
The Voltage was 24,5
So this makes 24,5V x 9,4A = 230,3 W x 27 Sek. = 6218,1 versus 7744 for 1 l gas
or: 230,3 x 27 /3600 = 1,72Wh  versus 2,15 Faradays 100% Efficiency
So you can see, i have still over efficiency with this simple brute force electrolyzer
and no one can deny. Think of this: If ever i would get over 10 Amps, the fuse in my amps meter would immediately be blown out. Well this was not the case and therefore, as long as the fuse is intact i can not be over 10 Amps. But even with 10 Amps i would still be at 1,83Wh  :-))
So this is definitely over efficiency.
Next week i will post my new video about making a drycell step by step. ;)
Nice day to you all
woodpecker
PS: Thanks to vonWolf
woodpecker
I have now reached  3,33Liters/minute with around 10 Amps
but i can not jet say exactly cause my amp meter only reaches 10 amps and I do`nt want to blow up its fuse.
woodpecker
pese
look at ampmeter, and regulate the supply so that it flow exactly 10 Amps
(9,99A)
so now use an copper- or iron wire (Last is shorter)
connect them between + and -(common)
to shunt the amp meter.
and calibrate the lengt ,of wire) in the way tat the AMPmeter
shown you -now- 5 Amperes.
Now you van use yiur meter up to 20 Amps.
(double the reading values)
Pese
