Dry Cell goes to Austria
Started by woodpecker, October 09, 2008, 07:29:04 AM
Farrah Day
Hi Woody
QuoteAND NOW I have ( and we all can have, cause its`s openly shared in this thread) an electrolyser, called drycell, with an output of 2,7 liters of gas/min at 10 Amps/24V = 240 W
We easily can have five such units and so we can get up to 13,5 liters of gas/ at 50 Amps/24V = 1200 Watt
2/3 of this HHO Gas, 9 liters/min, we know, is pure hydrogen, and this, after my own experience, is enough to run a 6,5 HP 291ccm Generator only by gas, This generator have a min. output of 2500 Watt.
But we only need 1200 Watt to generate the Gas. So what we have is a 1300 Watt of  free energy
Assuming, that i am lying, and we would need 50%!! more energy to produce the gas, then we would need 1800 Watt to generate the gas and would still have a 700 Watt of free energy, hour by hour.
Think about!
I look forward to you next instalment, but for now I have just one question. Can your generator deliver 50 amps continuously? Or even 25 amps?
I don't mean to put a downer on things, but do you not find this a bit of an issue.
Farrah Day
"It's what you learn after you know it all that counts"
woodpecker
Hi Farrah Day
QuoteI look forward to you next instalment, but for now I have just one question. Can your generator deliver 50 amps continuously? Or even 25 amps?
The 2500 Watt Generator should be able to deliver at least 10 Amps/ 230 Volts, with my starter/loader for cars which transforms the Voltage to 24 volts, the starter/loader is able to deliver about 40 Amps. So  its not the Generator that delivers the Amps, its the starter.
But this is not the best way to work, cause the starter too needs some energy, so it would be better having a cell of about 133 plates running direct on 320 V DC but using only
2-3 Amps.
LG woodpecker
Farrah Day
So instead of making a small high current, low voltage electrolyser you intend to make a large (many cell) high voltage, low current electrolyser. I see the logic and it will be interesting to see if you find a way over overcoming the losses.
I will be following your progress with interest.
Farrah Day
Cherryman
Hello Woodpecker,
Do you have an update yet?
Regards, Cherryman
lltfdaniel1
Well what i would do is build a fuel cell and then close the 'loop' and it will be self running :D.
Then use the excess energy for something else 24/7.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
