Thanks to ALL for your help!!
Super deep penetration effect
Started by I_am, October 13, 2008, 04:26:53 AM
I_am
I have found interesting article from Belarus scienist, Ucherenko. The main discovery is in the following fact:
If you shoot 1 micrometer particles into metal wall, if speed of particle is less than 1000 m/sec it penetrates to several diametes (few millimeters) and energy balance is in agreement with CoE law.
If particles speed is about 1000 m/sec, you see strange effect - particles penetrate into metal for 100-300 mm and up to 1000 times of heat produced and new isotopes are registered and x-ray film is exposed if hanged close to metal plate. All those effects are impossible with chemical reactions.
If particle speed is further increased particles explode on metal sheet surface.
What do you think? We could build prototypes and test the idea.
http://www.science24.com/paper/927
http://hal.archives-ouvertes.fr/jpa-00255418/en/
Googe-translated aaticle with idea of reactor
http://translate.google.ru/translate?u=http%3A%2F%2Fwww.ntpo.com%2Fphysics%2Fopening%2F28.shtml%23%25D0%2590%25D0%259D%25D0%259E%25D0%259C%25D0%2590%25D0%259B%25D0%25AC%25D0%259D%25D0%259E%25D0%2595%2520%25D0%2592%25D0%25AB%25D0%2594%25D0%2595%25D0%259B%25D0%2595%25D0%259D%25D0%2598%25D0%2595%2520%25D0%25AD%25D0%259D%25D0%2595%25D0%25A0%25D0%2593%25D0%2598%25D0%2598%2520%25D0%2592%2520%25D0%25AD%25D0%25A4%25D0%25A4%25D0%2595%25D0%259A%25D0%25A2%25D0%2595%2520%25D0%25A3%25D0%25A8%25D0%2595%25D0%25A0%25D0%2595%25D0%259D%25D0%259A%25D0%259E&sl=ru&tl=en&hl=ru&ie=UTF-8
I_am
In 1974, the Belorussian scientist Sergei Usherenko opened effect extremely penetration micro-particles in steel barriers target of allocating huge amount of energy in 102 ... 104 times greater than the kinetic energy of particles. The paper provides an analysis of new energy cycles occurring in extremely penetration on basis of the theory of elastic quantized environment (UKS) under the unified field theory (TEP) - vacuum field is ultimately the only source of electromagnetic energy.
Il. 24. Bibliogr.: 23 refs.
Vladimir Leonov - the author of the theory of elastic quantized environment UKS - the first informal unified field theory, which revealed the structure of the vacuum (the vacuum field) and brings together all known interactions: electromagnetism, gravity, nuclear (strong), weak (Neutrino), winner of Russia's science and technology, active member of the International Academy of Ecology (Minsk), a member of the organizing committee conference «Modern Problems of Natural Science» (St. Petersburg), Ph.D. (Moscow).
1. INTRODUCTION
In 1974, a young Belarusian scientists Sergei Usherenko was experimentally opened effect penetration extremely fine particulate 1-1000 microns in diameter solid metal barrier (target) with the anomalous allocation of energy in 102 ... 104 times greater than the kinetic energy particles at the time of its impact on obstacles at a speed of about 1 km per second. Energy estimated the effect on energy spending microparticles thread-like channel in the thick target. Length thread-like channel to have reached up to 200 mm and even more. The calculations also show that the kinetic energy of a particle is all for penetration into the target at a depth of no more than 6-10 diameter of the particles. An effect is not explained from the standpoint of modern thermodynamics, electrodynamics, the theory of relativity and quantum theory, including quantum chromodynamics (QCD). Source tremendous energy in effect Usherenko did not have [1,2,3,4].
Energy to feed the target estimated value of 109 ... 1010 J / kg per piece. This is far in excess of energy in the chemical processes. In addition, the Usherenko, a spectral analysis cuts and abrasive channels formed affair microparticles in thicker targets, helped discover new elements. As targets have been subjected to bombardment of microparticles in extremely penetration also detected the presence of radon gas, which initially was not studied samples. X-ray film set in the target zone was exposed. In some experiments of zasvetki was ruled. This indicates that the phenomenon is extremely penetration of microparticles in the barriers associated with synthesizing complex and unexplored high-energy physical processes that characterize particle physics and atomic nucleus.
Undoubtedly, the effect Usherenko is the greatest fundamental discoveries in the history of science, comparable with the opening of the effect of electromagnetic induction and Faraday radioactivity Becquerel. Surprising only cool attitude towards this opening for a quarter century of academic science, although the original observable effect extremely penetration, as the pilot of fact should draw special attention to the professionals. The situation is quite logical explanation. This lack of fundamental knowledge, especially in the field of energy interactions of elementary particles and atomic nucleus.
If unable to explain the nature of the phenomenon, the seemingly non-existent phenomenon itself. Indeed, so far unknown structure of any of the elementary particles, including chief: electron, positron, protons, neutrons, electronic neutrinos. Unknown mechanism for the synthesis of elementary particles and their mass. Undisclosed nature of nuclear forces interacting nucleon inside the atomic nucleus. We know only that the release of energy in nuclear reactions caused by a defect mass of the nuclei. But we do not know the cause of education of the masses and inertia, the reasons for the equivalence of mass and energy that derive in the nature of gravity.
And finally, to understand the interactions of energy needed to deal with the nature of gravity, because the weight is the sole source of the gravitational field, while the battery's electromagnetic energy. We need to recognize that since the time of Newton in that direction almost nothing has changed.
Attempts to unite Einstein's gravity with electromagnetism in the general theory of relativity (GR) proved unsuccessful. Do not place the UTO and a new theory of gravity, as was unable to disclose the nature of gravitational interactions. Actually, more like the theory of relativity theory of linear measurements of various observers, when an unknown absolute speed in space, but not as a fundamental theory.
Modern quantum mechanics is also not a complete science, much less talk about its fundamental, as it is and the UTO, did not disclose the reasons for the physical interactions of elementary particles, and noted their group behavior and condition, with the formal mathematical calculation device statistics. This also applies to quantum chromodynamics (QCD) attempts to explain the structure of nucleons, as if composed of specific particles - quarks - the fractional electric charges. But quarks - hypothetical particles not detected experimentally.
So, identified the main problems that needed to be addressed in order to explain the phenomenon Usherenko effect. And these problems have been solved in the theory of elastic quantized environment (UKS), which first revealed the electromagnetic structure of the vacuum, as the most energy-matter and the only energy source (fifth force), originally stored in the universe. Such an approach would explain the nature of the four known interactions (forces): electromagnetic, gravitational, strong (nuclear) and weaknesses (Neutrino), with common positions, joint fifth force [5,6,7]. Based on the analysis of the structure of the vacuum field were analytically solved the above problems related to the effects of extremely penetration. 6
At the time of my acquaintance with Sergei  Usherenko in 2000, has already become a doctor of technical sciences and director of the Research Institute of pulsed processes in Minsk, the theory UKS has been formed. There is a need was just time to understand the physical phenomena in effect extremely penetration of microparticles in the barriers and their linkage with the theory of UKS. This has enabled us already jointly developed the original program and methodology of experimental studies of electromagnetic phenomena in effect Usherenko, and a range test. In the near future, these materials will be published by us.
Usherenko used in their experiments fairly cheap disposable explosive boosters cumulative type. But the results of his unique. Such an effect is virtually impossible to obtain even the heavy-particle accelerators. Accelerated to a speed of 1 km / s, dust silicon 1 micron in diameter increases its kinetic energy to 0.61 .10-9 J (3.8 .109 eV). For comparison: proton synchrophasotron in Dubna (JINR) is able to disperse the maximum energy protons to 9 .109 eV, that is, until energy commensurate with the kinetic energy of the dust, broken all up to 1 km per second. But the protons must inform speed close to light speed (0.99 C). To implement the diameter of the proton accelerator ring synchrophasotron in Dubna at 72 meters.
For micro diameter of 100 microns, its kinetic energy at a speed of 1 ... 10 km / commensurate with, and even exceeds the energy of elementary particles made supercomputers on the accelerator in the modern scientific complex CERN (Geneva), accelerator ring which is the perimeter of 27 km. Naturally, the construction of ever more powerful accelerators of elementary particles at high financial costs, which are not commensurate with the costs needed to open Usherenko effect. There is the fact that a strong passion in the second half of the twentieth century accelerator technology only for elementary particles are not allowed to develop research in the field of micro-fine acceleration, including, was lost to study the fundamental processes of the bombing of obstacles micro-particles in extremely penetration.
Undoubtedly, the fundamental aspect of opening Usherenko lies in a fundamentally new energy technologies, perhaps the major energy technologies in HH1 century. It can be assumed that the effect of extremely penetration in the energy sector, will in the near term to exclude environmentally dirty uranium technology in the production of energy, and make a safe and manageable working reactors at nuclear power plants (NPP), using new types of nuclear fuel.
It is encouraging that as fuel in nuclear reactors can be used a new type of micro size 1-1000 microns any solid material, including the usual sand (silicon), whose stock in the Earth's crust are disproportionately large compared with reserves of uranium, and mining it is not difficult . To that end, micro must disperse to a speed of about 1 km / s and hit on a solid fuel barrier (target).
For example, in accordance with the principle of equivalence of mass and energy, even minute dust from the silicon (density 2.33 .103 kg/m3) in diameter all 1mkm (weight 1.22 .10-15 kg) accumulates a huge reserve of energy - 110 J ( 6,85 .1020 eV), determine the maximum energy substance 9 .1016 J / kg. For comparison: during the combustion of 1 kg of fuel energy is allocated 4.4 .107 J, a renowned nuclear and thermonuclear reactions are characterized by energy fuels 1013-1014 J / kg.
In experiments Usherenko already reached the level of specific energy 109-1010 J / kg per piece. This is far below the characteristics of enriched uranium fuel, but far in excess of the chemical energy of fuel, nearly three orders of magnitude. It is important that the process of energy in extremely penetration is not an explosive nature, easily controlled and monitored.
Naturally, the explosive boosters, for several reasons virtually unfit for energy in the new reactors. But now it is not a specific application of this type of accelerator in the new energy cycle reactors. What is important is that at such a primitive and cheap device Usherenko established the existence and effect of extremely penetration anomalous allocation of energy. In his credit. And if there is a need to develop better accelerator systems, such systems will be developed. This decision has been purely technical tasks.
The originality of the opening Usherenko is precisely in an area that no one of the greatest physicists of the twentieth century was unable to predict. Nuclear energy trying to build, based on advances in nuclear weapons and uranium technology. But uranium and its components - it is just a new type of explosives far more powerful, compared with dynamite and gunpowder. But no one in the head did not invent the idea comes to use as a  powder fuel. Sooner or later, a furnace fly in the air.
I believe that the use of enriched uranium fuel for power generation was some haste. Example of this - the Chernobyl disaster. This is on one side. On the other hand, has accumulated vast experience in the design, manufacture and operation of nuclear reactors and the construction of nuclear power plants. Our challenge - this task has been easier. There is a need for the existing nuclear power plant
replace the reactors with uranium fuel for reactors, a new type of working literally on the sand. This is the reality of opening Usherenko.
No doubt that such luck for the scientist, as the opening of the effect extremely penetration of microparticles in the barrier, falls quite rare. And, of course, would like to see Sergei Usherenko among the new Nobel laureates. Moreover, his discovery will help mankind, finally, solve the energy problem based on clean energy technologies.
I think that this will be a pleasant surprise to experts in the field of theoretical physics, particle physics and atomic nuclei, nuclear power.
2. ANOMALOUS energy
IN EFFECT USHERENKO
Open the device to read. Using an electric detonator 1 produced undermining charge 3. The explosion top of the device (2 and 6 cups,
8
Figure 1. Scheme cumulative explosive single micro-accelerator to produce the effect extremely penetration (Usherenko effect).
1
2
3
4
5
6
7
8
9
In Figure 1 presented a pilot scheme Usherenko device, which reproduces the effect of extremely easy penetration of microparticles in the barrier [1]. The device is a single type of explosive accelerator to fine powder materials sizes 1-1000 microns, and allows them to dissipate speed of about 1 km / s or more.
The device includes: an electric detonator, 1 cup 2 for an explosive, explosive (explosive) charge-3, the cumulative reflector 4; fine powder 5, 6 guide glass, steel target-barrier 8. In Figure 1 shows the flow of 7 accelerated micro-channels and 9-of micro-thick steel target of 8.
Glass 2 calculated on the amount of explosives and 200 d. An explosives used ammonal etc. Glasses 2 and 6 are made of plastic. reflector 4) destroyed. The existence of cumulative reflector 4 allows you to create a stream of micro-7 in the form of high-speed jet directed towards the target 8. If you blow on the face targets 8 bulk of the flow of 7 microparticle impact, dispersion of different angles in space. And only a small portion of microparticles interact with the target in extremely penetration.
A possible reason for the low efficiency of the accelerated flow of particles is high heterogeneity of the material particles and the uneven distribution of velocities in the flow, typical for explosive accelerators, as well as practically weak study the interactions between particles with a target at the time of joining the regime extremely penetration in the surface explosion. It seems that the regime extremely penetration should be characterized by a critical parameter. At the beginning of this option, call it test Usherenko (Yδ), you can take the attitude of the particle velocity v at the moment of impact on target to its diameter d
Ykvdδδ = (1)
where kδ = 10-6 with - the rate dimension.
The availability rate in kδ (1) allows the test Usherenko seen as crazy amount. Multiplier 10-6 makes very convenient value criterion in the calculation for micron particles. For example, the particle diameter 100mkm (10 4 m) at a speed of 1 km / s (103m / s) value criterion Usherenko of 10 units. For a bullet diameter of 10 mm (10-2m) at the same speed of 1 km / s test Usherenko determined by the number 0.1. Microparticles with the criterion of 10 units is to extremely penetration, and a bullet with the criterion of 0.1 is reflected upon impact of a strong barrier.
Of course, that the regime extremely penetration has some critical range of criteria Usherenko to be set in subsequent experiments. It seems that during the regime below the critical criterion Usherenko will occur rebound particles from the barrier, or a small entry barrier to a depth of several diameters. With very high test Usherenko when struck by a particle on a target will be a blast particles with the formation of the target crater, defining mode of cavity formation  that is not characterized by abnormal energy, as seen in the extremely penetration.
In any case, the study of regimes extremely penetration requires setting basic experimental research in a wide range of criteria Usherenko for various materials such as particles of the drummer, and target-barrier. Despite the fact that on this issue by Usherenko and his colleagues, much work, but their work was aimed at the creation of new composite materials. Now you need to translate research Usherenko effect in the area of new energy interactions.
According to the most Usherenko abnormal energy in extremely penetration in more than 100 times the kinetic energy of a particle at the moment of impact on target [1, str.117]. To realize the regime extremely penetration must increase the density of energy in 2085 .103 times [2, str.89]. Naturally, it is certain averaged data.
Vladokv
It is cool, but looks not practical. I think it is too slow(too weak to use). Similar to simplified fusion
