Silicon Salt Battery
Started by Thaelin, October 16, 2008, 08:08:19 PM
triffid
I'm talking about books from the 1930's and 40's.Triffid
PhiScience
The function of science is to make observations and measurements and to find correlations between the observed facts.
triffid
I found one of my books with the lead battery and edison battery cut -away views.Its an electrical book,not electronics like I thought.It's;
"Fundamentals of Electricity" by Kennard C. Graham,E.E.
Fifth Edition cc1968
first edition was 1943.
A fact it mentions about the edision battery was that it could be frozen solid
and once thawed again it would be ok.Triffid
Go to your  local library or go to the book section of your local thrift store to start your own home library.
triffid
I found a simple storage cell experiment in an old book.Auto lead battery.Apparatus:two lead plates,about 4 inches square;dilute sulfuric acid;insulated wire;battery jar.You should have enough info from this to go further if you want to.Always practice lab safety,wear safety glasses when working with acids.I have found no simple experiments for edison batteries.The electrodes are not so simple.The positive plate consists of nickel plated,perforated iron tubes filled with nickel flake and hydrated nickel oxide.The negative plate consists of nickel-plated,perforated iron cells or pockets filled with iron oxide.The electrolyte is potassium hydroxide.Some other facts about edision cells are they can be completely discharged and suffer no damage.They can also last 100 years so if you run across some anywhere.Buy them!Triffid
triffid
The edison battery is half the weight of the lead battery.And the maximum voltage of the edison cell is about 1.25 volts so it takes 5 edison cells in series to furnish the same volage as 3 lead cells in series.Triffid
