plans to build woodgas system for cars and traktors
Started by hartiberlin, November 11, 2005, 08:24:05 PM
hartiberlin
Hi All,
here is a PDF File which shows how to build a woodgas system.
Pretty interesting.
Maybe this could be scaled down to run a 2 KWatts emergency power
generator ?
Regards. Stefan.
P.S: Thanks to Walter for finding this file,
Clara Listensprechen
Sounds almost exactly like the production of water gas.  Run steam across hot coals and you get water gas (mostly hydrogen) with the byproduct of carbon monoxide.
I posted details about this primitive process (and others) on the Gathering of Scientists forum.
pese
I think , some smaller items , will be also intersting.
see picture.
can onyone find more over this??
http://pixerve.de/39695/pese.html
Slipmatwax
The wood gas process uses limited amounts of combustion air in a sealed chamber so the wood only partially combusts. The wood gives off gas but does not have the adequate amounts of air to fully burn. The syn-gas is then piped into a diesel engine where the un-burned gas is used in the combustion process.
There are some issues with getting the off gasses clean enough because of fly ash in the  gas.
bwb
I thought some on here like to see this.I have been working HHO and the plasma arc,But my brother has started playing with the ideal of compressing woodgas in a tank to run whatever with from a car to a generator. He plans on building a big enough wood gas processor to compress large volumes of gas if his testing plays out.Below is a short video of the burning gas after he compress a small tank to forty pounds.
http://www.youtube.com/watch?v=R2N0a6Swi00
