Qin Gang's Tumbling Routine
Started by TechStuf, October 21, 2008, 03:24:28 PM
TechStuf
@gyulasun,
QuoteThis makes a huge difference in the operation compared to the case of using normal incandescent light bulbs which would be always loading the coil hence would cause a much bigger Lenz drag!
Yes that lenz certainly can be a drag!
Force coupling the wheel work of creation was never intended to be easy.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
gyulasun
Hi TS,
I forgot to include another fact which can make drag also reduce:  the answer is still using LEDs...
LEDs are basically diodes and able to conduct current in one (forward) direction so say if some groups of LEDs flash up during  the positive half wave of one induced peak voltage periode, then this same group of LEDs will not load the coil in the negative half wave of the same induced peak voltage periode, ok?
By the way, what would you ask from Mr Gang?
rgds,  Gyula
TechStuf
I actually googled 'periode'!   :-[  (Always ready to learn)
QuoteBy the way, what would you ask from Mr Gang?
I've simply asked various questions....basically wondering if he has noticed or exploited potential areas for efficiency increase.
Why.  Do you see any, perhaps?
Areas for efficiency increase, I mean.
TS
gyulasun
Hi TS,
Sorry for the typo, I meant period and should have used the word cycle instead. English is second language for me.
Of course I meant technical questions  :)  and possible areas for efficiency increase may include the shape of the magnets and also the shape of the coil.
rgds,  Gyula
TechStuf
QuoteSorry for the typo, I meant period and should have used the word cycle instead
Well, we must admit, the word "periode" sounds plausible in the hyper-morpholigical language that is 'English'.  Google it in a month or two, it'll probably be real by then!
I like your ideas....coil and magnet shapes.
There's something about that tumbling sequence though......
Something.
TS
