Bedini motor with Avramenko plug OU COP = 1.1
Started by hartiberlin, October 23, 2008, 08:22:58 PM
nul-points
hi all
it would be great to find that someone has finally measured OU output generated by a Bedini motor setup
before we get too excited with this latest report i think we need to see:-
- the exact circuit being used
- where in the circuit the measurements are being made
- if the builder's taken all necessary steps to ensure the measurements are valid (eg. is the output a pulsed waveform? if so, does his meter give a true Average Current reading for this waveform?)
- if it's possible to confirm the output results using a second method (eg. scope trace data & Excel)
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
pese
at least ....
you cant see the input voltages not the output voltage
if the output voltage is half of input voltage ... ?
than the losses are more then 50%. (if near equivaltent current)
Any SHOW is an nonsense if it not displayed
  the voltage AND the Amps ! ( (V time A = VA (Watts))
so the next problem in this Video is:
Motor is DC driven !
Output is this way  AC.
No  belive any video or scematic , take an lttle "basic-sciences"
first.
GP
Groundloop
@nul-points,
Good point. He is using two digital multimeter's to measure the current.
There is no way the measurement can be correct when measuring pulsed DC.
Only a true RMS meter or scope readings can confirm the measurements.
@pese,
I agree with you, there is not enough information in the video to confirm o/u.
Groundloop.
Groundloop
@Nostradamus2,
Closing the f...ing loop is not easy with pulse motors. If you build a pulse motor and use
a lead acid battery (LAB) on the input then the input impedance of you motor is very low. The internal
resistance of a LAB is typically in the mOhm range. So, if you just connect the output of your
motor direct to the input battery then you have "killed" the output voltage. It will not work unless
you find a way to impedance match the output with the low resistance of your input battery. I do not
say that this is impossible, it is just difficult to do.
Groundloop.
