Thanks to ALL for your help!!
how ZPE works. (simple).
Started by nitinnun, October 25, 2008, 01:27:37 AM
nitinnun
1:
a "universal energy", charges up all atoms in the universe.
ALL atoms recieve this energy.
2:
some atoms "modulate" this universal energy, into clockwise spinning magnetism.
(such as copper)
other atoms modulate this energy, into counter-clockwise spinning magnetism.
(such as iron)
3:
ALL magnetic fields, are made of clockwise spinning magnetism at their positive pole,
and counter-clockwise spinning magnetism at their negative pole.
(electrical potential, is a magnetic field. *hint* *hint*)
4:
covalently bonded atoms, merge their magnetic fields together.
into one big magnetic field.
ANY covalently bonded atoms, form this one big magnetic field !
no matter if it is water, or a rock!
the longer the covalent bond chain, the more atoms that are sharing their magnetic fields!
5:
if a "clockwise generating atom",
and a "counter-clockwise generating atom",
are covalently bonded together......
then both of CW spin and CCW spin, are present in its magnetic field!
this magnetic field gains magnetic flux!
6:
this atom-fed magnetic field, gains potential.
until the clockwise magnetism and counter-clockwise magnetism,
overcome the electrical resistance of the polymer-molecule.
the moment the polymer-molecules electrical resistance is overcome,
the CW magnetism and CCW magnetism merge together into electricity.
the higher the electrical resistance, the greater the magnetic build up, before discharge happens.
polymers can be made of many types of atoms.
(even rock)
but glue polymers, are covalently bonded carbon and hydrogen atoms.
these glue polymers are mixed with water.
when the glue dries, there are just polymer chains left! forming a rock.
when these polymer chains bond to a piece of copper and a piece of iron, the copper and iron merge their magnetic fields, with the glues magnetic field.
when the clockwise magnetism of the copper, and counter-clockwise magnetism of the iron,
are present in the same magnetic field,
that magnetic field gains power.
i've done this with copper and steel dried together in glue.
but i'm interested in forming a crystal lattice,  to create millions of tiny copper-polymer-iron molecules.
nitinnun
by the way.
larger atoms have larger magnetic fields.
so the larger the atoms making up the polymer chain, the larger the voltage potential.
because the larger the magnetic field, the larger the maximum magnetic potential.
similar to how bismuth makes more voltage and amperage than copper.
because the bismuth atom is larger. having a larger/stronger magnetic field.
nitinnun
any source of clockwise spin and counter-clockwise spin, can be turned into electricity.
known sources of CW/CCW spin, are :
CW spin generated from the sky.
CCW spin generated from the earth.
CW/CCW spin generated by different atoms.
spinning magnets (one wheel of magnetis spinning clockwise, a second wheel of magnets spinning counter-clockwise).
nightlife
nitinnun, I see you have been doing some thinking out side of the box. :~)
Keep going because you are starting to get it. You must keep in mind that atoms contain a magnetic field within themselves and the vibrance of their magnetic field is what gives them their individuality as well as tells what they are attracted to and what they are not attracted to.
ZPE is the pulse that creates the vibration but it takes two colliding resistances to create a pulse but it takes vibrations to create resistances. Therefore, we end up with a cycle that keeps repeating its self just as a magnetic field does until the vibrance wares off.
Nothing last forever, not you, me, the earth or anything else. The trick is trying to find as way to use one vibration to release more that are stored unless we could find a way to use one vibration to create a more vibrant vibration and if we could, then we could say over unity is possible but that has yet to be done.
EELRIJUE
I had been studying the ZPE field in lieu of David Hamel type physics for a number of years.
From what I have learned, the ZPE is a creation field. Very high in vibration. Full of all possible dimensions of the known universe. The laws of physics break down at this field.
All matter is created via this field. All matter which is converted to energy works back to this field.
How do we make resonance to this field? Using vibration, which is high enough to properly couple to it. hamel physics use a technique of chaos induced vibration. Basically, runaway vibration. A machine seeks out the highest rate of vibration possible in it's design. In doing so, it zeroes in on the very high ZPE frequency. Like an antenna which can match the incoming frequency, like a radio antenna/tank circuit zeroing in an FM station.
ZPE field vibrates very high. Great power is locked away in frequency cycles. So, through resonance, you can tap into this great power and through natural processes of down conversion, you can use this energy.
Using larger structures, such as the hamel machine, you are creating the conditions to make possible, for resonance. Metal structures vibrate. Of course, atoms in the metal vibrate along with the structure's vibration. Using matter, it's self, to vibrate fast enough to seek out the energy state or the ZPE.
Basically put, vibration is "a" means to tap the ZPE solely and efficiently. Spin is another. Geometry makes both possible.
