Thanks to ALL for your help!!
Simple Radiant Energy Generator
Started by Dogs, October 27, 2008, 06:40:04 AM
nievesoliveras
Hi!
I had a similar idea but with just one transistor.
Jesus
Dogs
Quote from: nievesoliveras on October 29, 2008, 02:33:07 PM
Hi!
Jesus
@pese, Thanks for the input. If my test fails, I won't feel so bad.
@nievesoliveras, I did try a few flavors of a 2 switch circuits, unfortunately with no results.
I did get 3x higher Voltage readings (oscoped) at one point, but the circuit
did not seem to be charging the cap.
So I think that I only got the short going between the Power Supply and
the Choke right. But the part that sends all of that energy into the cap was not
quite there.
I did not make schematics of those circuits.
If you get a chance to try out your circuit, please let me know about the results.
Best,
-Dogs
Dogs
I have made a correction to my second circuit to fix the polarity of the connection between the Choke and its Transistor Switch.
The main problem that I can see with this circuit is that the transistors rectify the energy caused by the short. This may cause a loss of the energy spike that accompanies the shorting of the circuits. This would not happen in a mechanical switch or a JFET type transistor. Any how, it will be interesting to see what happens.
-Dogs
nievesoliveras
Hi!
I am just waiting for the parts I sent for. As soon as I get the parts I will make the tests.
Jesus
leo48
The scheme is a serious mistake on the transistor polarizazione Central!
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
