Thanks to ALL for your help!!
Chernobyl Fungus Feeds On Radiation
Started by PYRODIN123321, October 31, 2008, 03:48:44 PM
triffid
turbo
fungus is the world oldest life form, it has been around longer then anything else on this planet.
some of it's fruit cause psyco active responses in our brain and unlock certain weird effects like telepathy.
i have done some experimenting with this and the effects are verry real.
the sober person i tried to reach confirmed she noticed " my spirit reached her " as she told me the day after the experiment.
the effect is increased when one takes the maoi breaker like syrian rue seed along with the fruits of the fungus (mushrooms)
The seed contains a component called telepathine and this enhances the effect.
it was sometimes a scary experience and i'm not going to do it again, but it does work and the persons you love can notice it even if you are miles away.
Marco.
PYRODIN123321
Well I would be only slightly suprised to find out people have some hidden abilities, i mean we use only a little of the available brain, so if you short circut the whole brain with a fungus, we might be able to use a little more of that thing we call a brain.
Peace.
RunningBare
Quote from: PYRODIN123321 on November 14, 2008, 03:27:29 PM
This is a myth, while I agree we may not use the entire brain, a large part of it is used, the brain is not just about intelligence and thinking, it's a complex control system with sensory centers, motor controllers, balance controls.
The problem is not capacity but connection, for best creativity and resourcefulness for instance the connection between both half of the brain need to be good.
The myth that we only use 10% of our brain is just that, a myth.
juice
Maybe they're just growing more because of the heating... this hypothesis must be tested before claims that it is the ionizing radiation and not just the result of the heat it transfers...
You might just as well say that bacteria are supercharged by microwaves if you constantly heat up a culture at a rate sufficient to keep it at a higher temperature at which the bacteria thrive.
