Bedini SSG puts out 800 volts using auxilary inductors!
Started by supermuble, November 02, 2008, 08:43:07 PM
innovation_station
i have not yet done a dwg of my unit altho it is much similar to what has been showen
however my batteries are not wired exactally as showen ...  nor is my coil  i beleave im switching  the neg....  not the pos..  pos  from the primary battery goes to the primary coil ....  then secondary battery is tied to primary battery ...  it is pos from pri and neg from sec  charge goes to pos secondary when wired properly u will get 24 v across both and 12v independent of 1 another.....
i will some time hook this my way and take a pic for you
i also have a full wave  bridge rectifier after the cap to convert it ALL TO dc  if you want higher voltage kicks then lower the selfinductance of the primary and rise the high selfinductance of the trigger...  i will use...... when i make more coils 14ga and 30 there bouts...
i also uped my resistor to a 1k 4 w   it burnt out my 3055  in 10 min ....   but it could be a loose connection ...  im not sure at this time ..
ist
nievesoliveras
supermuble
Here is the diagram drawn correctly.  ;D The previous diagram should be changed since the coil wires are drawn incorrectly (thanks for trying though!)
nievesoliveras
Hi!
It seems that none of my guesses were good!
Thank you for the schematic.
Jesus
nievesoliveras
Hi!
Pardon my ignorance, but I dont understand the extra coil on the trigger circuit.
Jesus
