Bedini SSG puts out 800 volts using auxilary inductors!
Started by supermuble, November 02, 2008, 08:43:07 PM
identity
mine using a bedini fan 24 volts with a flyback connected in parallel with power coil. It goes into self oscillation, my input voltage is 12 volts and my charging volts is reaching 110volts dc and 90 - 130ma output. Using the same set up but with an ignition coil instead of the flyback, my output is only 20volts dc and 200-500ma output. With only the bedini fan, im getting only 5volts and 60-75ma output. :)
nievesoliveras
Hi!
Thank you pese!
@identity
Quotemine using a bedini fan 24 volts with a flyback connected in parallel with power coil. It goes into self oscillation, my input voltage is 12 volts and my charging volts is reaching 110volts dc and 90 - 130ma output. Using the same set up but with an ignition coil instead of the flyback, my output is only 20volts dc and 200-500ma output. With only the bedini fan, im getting only 5volts and 60-75ma output.
Do you have the drawing of that?
Jesus
innovation_station
i have found by useing a POLIRIZED COIL  i can use an external magnet to rev it up :)
also my output is close to 200vdc  that is what charges my battery
also with the polorized coil results are much better
i have the exact same setup with out polorized coils out put is around 90 -120v   i droped the pots... as i aint spinning anything.. so no need to ballance it
ist
my curcuit is not the same a bedini .... close but not the same
nievesoliveras
Hi!
@innovation
If it is not a too complicated circuit, can you show it?
Jesus
identity
a bedini diagram for the ignition coil or the flyback mods.
a multi coil diagram.
