Bedini SSG puts out 800 volts using auxilary inductors!
Started by supermuble, November 02, 2008, 08:43:07 PM
supermuble
Identity, could you post your circuit. Just draw it up with Microsoft Paint?
I am interested to see what you did with the ignition coil. Right at the moment, I am experimenting with putting my auxilary coil in series with the drive coil. After lots of testing, I was not able to charge my batteries using an auxiliary inductor coil on the negative battery terminal.
Stanley Meyer, the guy who designed the hydrogen Voltage Intensifier Circuit (VIC), he said that you can step up voltage by placing inductors in series. I think our Bedini motor is similar. The more coils you add in series with the main coil, the larger the back EMF voltage spikes, provided you hook up each coil the same way, with the same diode in the same location.
nievesoliveras
Hi!
Long time ago I did this fan charger. The second graphic is the original from imhotep's instructions, the first graphic is a mixed circuit with a self running bedini motor. It just worked once. Worked about 24 hours and it was charging its own batteries. I was so happy that I changed the charged batteries for other that were not charged and the thing quitted to work anymore till today. Any Ideas?
Jesus
nievesoliveras
Hi!
@pese
Quotehello,
than is a little bit difficult to understend...
o will explain a little bit
this way of current loop mus be closes.
if he think to take bifilar coil
( i think , if, than an pankake coil , , in way og befilar an bifiolar as to wires.
(1. will be o inputs at aotside. the to wire insided connecte together. othes , you will try . one side outsid use an input. zhe inner wire of sam ire connecte to the second wire at otside, and use the inner side (of coil) from this 2. wire as 2. pole for input.
Try this, the rest of circuit is near equivalent to all othe desings thas was shorn
and i loced now over 6 years.
possibly ((but i dont strong belive) can it be possibel to find with teslas pancake coil
other results - because nobody have try this... (some in the inductance will not refer an be compatibel with other zylindical coils.
good look
Gustav Pese
I quite do not understand your written words, but this guy made a post  here:
http://www.overunity.com/index.php?topic=5921.msg136069#msg136069
and his own words maybe can answer your question.
Jesus
identity
supermuble, diagram i post is the same schematic i use for my bedini fan ignition coil, to make it simple. just connect the positive terminal of the ignition coil to the + termininal of the source or primary battery, and connect the negative of the ignition coil to the collector. You will notice in the diagram that the ignition coil is connected  parallel with the power coil. Hope this help. ;)
innovation_station
i have not tryed this style set up ... yet
however i got a new one  ;) ;D
ever use this curcuit on a tv flyback tranny?   then put 6 in a circle....  and rotate it through sequencial pluseing ...  hummm  30000v from a 9v any one??    x6   sounds like some sierous free cake ... ;)
ist
