Thanks to ALL for your help!!
magnetic monopole
Started by GestaltO, November 08, 2008, 12:29:33 AM
AbbaRue
Is there anywhere I can find out more about this magnetic monopole concept without reading all that junk about
government suppression?
I want to know more about it, I don't quite understand what a magnetic monopole is supposed to be.
Or how to make use of one once it is constructed.
gyulasun
hello GestaltO,
The person involved in your link, James Fauble has been a member here since 2005 (though was active till last year).
His member name is BushWacker on this Forum.
His topic is here on Harmonic Oscillating Power Electric Generator: http://www.overunity.com/index.php?topic=358.0
Unfortunately, his claims proved to be exagarated as far as I could conclude.
I did not know about his monopole magnetic materials: The materials of which I am referring, were (high energy magnetic monopole materials) with resistive forces of at least 10 to 20 tons per square meter x 1/4" thickness.).
If such materials already really exist, then it is not a mere unluck we have no any news on them. Hopefully sometimes in the future we shall learn and use them... But if they do not exist, then hopefully further research can create such materials.
rgds, Gyula
GestaltO
oh cool, thanks Gyula.
@abbarue
best bet is to type in magnetic monopole into google. wikipedia has some relevant information too.
Basically a magnetic monopole is a magnet with only one pole.
imagine if you cut a bar magnet in two direct in the center and instead of getting two smaller dipole(north and south) magnets you got 2 monopole magnets 1 south and 1 north. the effect would be that the north monopole magnet would repel other north sides of any magnet however it would not attract the south pole of a magnet as any dipole magnet would.
the uses are many, but mainly that you could construct a generator very very simply using only magnets to propel it making a true perpetual motion device.
Everything is energy. Atoms do not exist the concept is outdated. All energy is transferable to another form of energy, we just have to know how.
Liberty
Quote from: GestaltO on November 09, 2008, 02:34:10 PM
@abbarue
You really don't need or want a monopole magnet.  The common magnet with a North and South pole is what you need.  A North pole by itself is useless without a South pole to seek.  A South pole is useless by itself without a North pole to seek.
Consider this analogy.
Imagine, having only a positive terminal of a battery or power supply.  Then expecting to run an electromagnet with it that has two wires (one plus, the other minus).  It is about the same thing.
Liberty
TechStuf
QuoteBasically a magnetic monopole is a magnet with only one pole.
Which is a misnomer of sorts, as such descriptor becomes wholly inadequate at the particle level.  A magnetic field is a closed system of RH and LH spinning strings which maintain symmetry.  Forcing a field separation breaks symmetry allowing a cascade of useful energy.  This is what happens at EM induction in a field coil, with commensurate losses.  Once one has proved to his or her satisfaction that the field model as taught at all levels of 'education' is incorrect and that virtual photon flow does not emanate from the N pole to the S pole but from both poles, each to the other.....more creative efforts may result.
Surely there's more than one way to "cut" field lines...
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
