Thanks to ALL for your help!!
Using magnets instead of bearings?
Started by irethedo, November 12, 2008, 05:12:59 AM
irethedo
Has anyone ever attempted to use magnets instead of bearings in a permanent magnet generator to support the rotator and to cut down on friction?
This seems like it could be a simple way to create a generator that spins freely and with little drag which might be ideal for a small wind turbine application or something that requires little force to turn it...
Any ideas on this or is there something out there already using this concept?
thanks
BEP
Lookup 'Halbach Array' and passive magnetic bearings.
They are used but rarely.
In my opinion if the motor can't overcome bearing losses easily then it likely won't work anyway.
Paul-R
Quote from: irethedo on November 12, 2008, 05:12:59 AM
This is an off-the-peg item. Try googling for "magnetic bearing" or
http://www.waukbearing.com/
Paul.
yaz
Here's a pic of a Halbach Array bearing setup using square magnets. Seems easy enough.
