Self Running Motor on You Tube??
Started by sm0ky2, November 13, 2008, 08:45:43 PM
nievesoliveras
@4tesla
I made a combined circuit that runs a newman motor with just a 1.5v battery. If I can make the circuit to use the battery and recharge it, for me that is a self runner.
@michelinho
It is difficult for me to visualize a circuit without a visual diagram. Do you have a diagram of what you are explaining?
Jesus
Michelinho
@nievesoliveras,
Sorry, I don't have a diagram.
Each coil is connected to the ac terminals of the rectifier bridges.
The red wire connects all the "+" of the rectifier bridges.
The black connects the "-" of the rectifier bridges.
Those two are your outputs of the alternator that connects to the battery and to the motor with a switch to open the circuit between the motor and the battery. He uses a terminal block under the stator for all his connections.
I'm running Unix now and don't have access to my usual programs.
Hope this helps,
Michel
nievesoliveras
@michelinho
I will try to draw a diagram with what you said and I will post it when I finish, so the group can make changes to it.
Lets see if we can replicate it even though the inventor does not give us any help.
Jesus
Michelinho
@nievesoliveras,
He is using 6 rectifier bridges, probably this model:
BRIDGE ( BR-5 ) - Model : KBP005-3 / Amp - Volts : 3 A 300 V
I bought 18 last week and they were easily identified.
Take care,
Michel
nievesoliveras
@all
Here is the preliminar circuit diagram. I will accept any new positive ideas.
Jesus
