Self Running Motor on You Tube??
Started by sm0ky2, November 13, 2008, 08:45:43 PM
Michelinho
@nievesoliveras,
That is the stator wiring diagram. The output gain by using a smaller rectifier bridge on each coil is probably why this is a self runner.
Usualy an alternator uses one hefty (35A) rectifier bridge per phase which is less efficient but less costly. To get a self runner, you must optimize everything and he is doing just that with his design. I am building an alternator and I bought one rectifier bridge for each of the 12 coils.
Bedini uses battery and one of is machine charges 5 batteries while discharging one but he never close the loop. Identical batteries.
Take care,
Michel
4Tesla
Quote from: nievesoliveras on November 16, 2008, 08:28:58 PM
@4tesla
I made a combined circuit that runs a newman motor with just a 1.5v battery. If I can make the circuit to use the battery and recharge it, for me that is a self runner.
@michelinho
It is difficult for me to visualize a circuit without a visual diagram. Do you have a diagram of what you are explaining?
Jesus
If it can run over 24 hours then I'll agree.  How long has this motor run?
Jason
nightlife
 This motor could run more efficient then it does by using double wound coils so the collapsing fields could be utilized.
I am also curious about what these are next to the motor.
4Tesla
I believe those are battery packs that were later replaced by a single 1.5v watch battery.  Some say it is just needed to start and then it is self-running??
nightlife
 I was thinking that but I wasn’t sure.
It would need a place to store the charge but it would have to charge at least what it consumes and it wouldn't need a charge to start, it would only need a spin to start it and for it to continue to run. It is a dc motor which requires a continuous current to keep running and the battery would supply that where as the pulsed current wouldn't and that is why a battery would be necessary to keep it running unless it used a centrifugal clutch set up but then the motor would turn on and off every time a pulse current was supplied to it.
