A SQUARE MAGNETIC RAIL -- ROTOR 360 ROTATION
Started by magnetman12003, November 15, 2008, 02:45:46 PM
Goat
nievesoliveras
@goat
Exactly that one!!!  http://www.youtube.com/watch?v=Yrxl8hx9wcU
The thing is that on one the posts there was a comment about what to do with the working model, and I thought that if it runs at that speed and a shaft can be added, the movement can be used to produce free energy.
Thank you! I will check the link!
Jesus
magnetman12003
Quote from: Goat on November 19, 2008, 10:17:04 AM
@ nievesoliveras
Is the video you are referring to this one?  http://www.youtube.com/watch?v=Yrxl8hx9wcU It was discussed in this thread
http://www.overunity.com/index.php?topic=3114.msg45488#msg45488
Regards,
Paul
Hi All,
I got into that spinning disk magnet group and did that.already. It has no bearing whatsoever to this project. Uses electricity.
Tom
magnetman12003
Hi Guys,
I am a member of that group thats spinning the magnet disk. Been there and done that. A spinoff is what you see in all my U tube videos. I have constructed many projects using that technology.  However it uses a small amount of electric energy to power that motion. $175 will buy you all info you need if you want to go that way. See TRACMAG
I always wanted to construct an all permanent magnet motor using nothing else but the magnets in the project to power itself.
Presently I see a possibility of making 2 track U turns.  One turn a little larger than the other. Take the smaller one and place the ends INSIDE the ends of the larger U turn.   Now we have coupled two open end track U turns within each other. Maybe we could get completete 360 travel this way?  Food for thought.
I like your track setup LIGHT
looks almost like mine. My inside track area measures 8 3/4 inches square.
Looks now I will try using my disk magnets to make a longer track. I run out of the block magnets.
I have a lot of round wood sewing hoops that old ladys stich fabric on. Those wood rings are perfect and can be bent in an oval shape in a hot water bath to make a track former. They also come in larger sizes and can be found on Ebay very cheaply.
Tom
magnetman12003
Quote from: TinselKoala on November 18, 2008, 09:36:40 PM
You are obviously using the wrong colors. Try getting some blues and browns in there.
Every working SMOT I've ever seen had blues as well as reds.
No, wait, I almost forgot--
There are (still) no working SMOTs !!
magnetman12003, I am curious to know what you think the problem was with Archer Quinn's various designs. What did he do wrong, that prevented his "sword of god" magnet wheel from working, and also his various SMOT attempts? Did he not have enough magnets, or not a long enough track, or what?
His track has to be long enough to allow the runner magnet to gather enough inertia to go past problem
areas with ease.  I am not sure also if he is using the same magnetic track structure we are using for the track rails here.  The track magnetic rail sructure here allows a runner to get up to speed very quickly and smoothly.
Tom
