Open "Free Source" ideas
Started by rlortie, November 16, 2008, 06:55:49 PM
helmut
Hello
I like to bring a new idea to discussion.
Perhaps some aspect is of use.
helmut
rlortie
Before spending time and material building MT 24 or anything like it I suggest the following.
Look at the original analytically and track the points of suspension. You will find that the weight transference does not change from open to closed. All weights are still carried by the same pivot points.  True, on one side the weights are closer to the axle but the path that supports them has not moved.
Both sides of the wheel are still symmetrically in balance. In fact you loose at 6:00 o'clock, you have two levers, one opening while the other is closing. You end up with both in contact at the bottom creating an obvious keel point.
Ralph
rlortie
 Yup! resting on the middle of 'it',,,  But what is "it" resting on????
Thaelin
   I just unloaded my idea and such in archers old thread. Enjoy.
thaelin
Thaelin
   Well, guess I will have to move it over to a new one by its self. I have to
head out for work but will be into it over the holliday. Look for the Grav-Gen.
thaelin
